February 04, 2026, 05:18:39 AM *
Author Topic: Different kind of front Directionals??  (Read 2071 times)
rmrc51
Palmyra, Virginia
« on: February 15, 2012, 06:47:59 AM »
In the picture below, you can see the light bar (I believe that it's a Cobra) that I have with the stock Honda front directionals. What I'd like to do is replace the stock directionals with a nice LED set.
Any suggestion or opinions?
VRCC # 30041
« Reply #1 on: February 15, 2012, 06:57:50 AM »
It is not a Cobra, Cobra's are flat on top.
As far as directional signals, any thing will work that you can mount on the black bracket holding the other light.
Otherwise you will have to run all over looking for mounting brackets.
I used to have some Quarter size lens LED's but some of the LED's burned out, so I went back to stock.
Here is a link to a good source, this is where I buy stuff from now.
http://www.radiantz.com/
rmrc51
Palmyra, Virginia
« Reply #2 on: February 15, 2012, 07:14:17 AM »
Maybe rather than replacing the entire directional housing, I'll try to find an amber LED bulb insert that simply replaces the current bulb.
VRCC # 30041
Joe Hummer
Arnold, MO
« Reply #3 on: February 15, 2012, 07:43:51 AM »
Check with your local auto parts stores.  I have a set of red 1157 LED bulbs in my rear turn signals that I converted to Run/Turn lights.  They have amber and I believe clears bulbs also.
Joe
1999 Valkyrie Interstate
olddog1946
Moses Lake, Wa
« Reply #4 on: February 15, 2012, 07:46:32 AM »
chromeglow.com is a good place to look. they specialize is LED products.
« Last Edit: February 15, 2012, 07:50:15 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #5 on: February 15, 2012, 08:18:07 AM »
Your light bar is a Big Bike Parts light bar.  Most likely, this one.....
http://www.bigbikeparts.com/Inventory/Navision/55-312?catalogNo=1
The instuctions for it are here.....
http://www.cruisercustomizing.com/installguides/BBP-55-312.pdf
Your best bet would probably be to shop at Big Bike Parts as they've already got stuff that'll mount straight to that light bar.
However, you've already suggested the easiest thing to do.....replace your bulbs with led's.  If you do, you'll need an led flasher relay to go with them to prevent them from hyper/rapid flashing.
http://www.bigbikeparts.com/Inventory/Navision/13-306?catalogNo=1
You can use a load equalizer, but they can generate alot of heat and finding a good place to put something that makes alot of heat on your Valk could pose a problem.
rmrc51
Palmyra, Virginia
« Reply #6 on: February 15, 2012, 08:24:46 AM »
BF,
Thanks very much for all of the detailed info!!  cooldude
It's been so long since I put this light bar on I had forgotten where I bought it from. Thanks again.  Wink
VRCC # 30041
JimC
SE Wisconsin
« Reply #7 on: February 15, 2012, 08:25:32 AM »
As stated above, you have a big bike parts bar, I bought these off of FleeBay somewhere, I really don't remember where. It took a little reworking, but nothing major.  Sorry I don't have a better picture for you. I did not have a problem with the LED's not working until I added them on the rear also, then I had to ad the load equalizer to get them to flash properly.
Jim
Jim Callaghan    SE Wisconsin
« Reply #8 on: February 15, 2012, 08:29:52 AM »
Yup! Rmrc51 is right, this is your light bar. He has the solution also to your quandary.
http://www.cruisercustomizing.com/show-chrome-accessories-big-bike-parts-contour-driving-light-kit-with-3-12-halogen-lights-vtx-valkyrie/part/BBP-55-312 :'(
My rides:
« Reply #9 on: February 15, 2012, 09:03:33 AM »
Years ago I installed Kisan's flasher that times out and shuts off - you can pick from several intervals.  Also pause the countdown if you connect the extra wire to the brake lights circuit.  Bonus, when I installed LED "bulbs" later I didn't have to deal with the wrong resistance - the digital Kisan circuit handles it.  I don't know what their current flasher's options are, if they are the same or they have added something.  I also rewired the rear marker lights so they are run, brake & turn, using red LED's on a board (24 per side, I think it was) that has an 1157 socket, inside a clear lens.
Brian
Monroe, NC
« Reply #10 on: February 15, 2012, 05:46:27 PM »
Look at the superbright LED website for replacement bulbs. They are good people and took a bulb back that I ordered wrong not charging me the added postage. Replacement LED bulbs are about 9.50 each.
rmrc51
Palmyra, Virginia
« Reply #11 on: February 16, 2012, 04:22:53 AM »
Thanks everyone for all of the great information!! As you all may have gathered, I'm trying to convert to LED's as much as possible.  cooldude
VRCC # 30041
sugerbear
wentzville mo
« Reply #12 on: February 16, 2012, 08:19:42 AM »
these people have a few.
http://www.d2moto.com/c-1220-motorcycle-turn-signals.aspx
Joe Hummer
Arnold, MO
« Reply #13 on: February 16, 2012, 09:01:11 AM »
Just make sure you replace your turn signal relay with one that can handle LEDs or put the load equalizers in.  I opted to replace the relay...went with an Optronics solid state relay.  I don't remember the part number but could probably find it if interested.  Another vendor may have one that is a direct replacement (meaning you don't have to cut the stock plug off) but I couldn't locate it when I needed it or didn't want to wait for it to come in.
Joe
rmrc51
Palmyra, Virginia
« Reply #14 on: February 16, 2012, 09:13:02 AM »
Joe
It looks like 'Big Bike Parts' has the load equalizer. I might as well get it from them being I have their Contour Light bar. I'm also considering using their LED directionals as they should also be compatible with that light bar.
Thanks for the suggestions!  cooldude
VRCC # 30041
sugerbear
wentzville mo
« Reply #15 on: February 16, 2012, 07:16:45 PM »
i'm sorry, i gave you the wrong website.
http://www.harrisonspecialties.com/mm5/merchant.mvc?Screen=PROD&Store_Code=HS&Product_Code=Chrome_MB_Amber&Category_Code=MiniB
Joe Hummer
Arnold, MO
« Reply #16 on: February 16, 2012, 07:22:59 PM »
One more thing...if you go with the load equalizers, i believe you have to put one on each led light.
Joe
rmrc51
Palmyra, Virginia
« Reply #17 on: February 17, 2012, 03:27:19 AM »
Joe
Thanks for the tip. I'll verify that.  cooldude
VRCC # 30041
« Reply #18 on: February 17, 2012, 07:19:23 PM »
With the signal minder you will not need load equalizers and will get a automatic shut off too. If you really want to you can have your signals do the parade signal and the alternate or finally have true 4 way flashers too. All with the signal minder. I have all leds including the reflectors on the side of the radiator, with the exception of the headlight and light bar road lights. Nice easy brighter and uses less power.  Eventually will convert the road lights too.
« Last Edit: February 17, 2012, 07:21:12 PM by Robert » Logged
