February 04, 2026, 05:22:32 AM
Wiring explanation needed...
Topic: Wiring explanation needed... (Read 1193 times)
PharmBoy
Lawton, Ok
February 15, 2012, 08:44:06 AM »
On the schematic of Chets START SWITCH SAFEGUARD. Does the blue/white wire connected to #86 terminal on the relay connect with the black/red wire as does the added lead that connects to the 30/51 terminal? Thanks for your help...Jim ???
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
tank_post142
south florida
Re: Wiring explanation needed...
February 15, 2012, 09:09:49 AM »
the drawing shows a connection in the bottom left, but i believe that represents the start switch.
otherwise the relay would be engaged all the time and it would never disengage during start process.
I got a rock
VRCCDS0246
PharmBoy
Lawton, Ok
February 15, 2012, 09:33:27 AM »
The way it is drawn up didn't make sense to me. That "connection" in the lower left portion of the schematic was what I was asking about. I have done this one other time on a Tourer, but could not remember exactly how it was done...Jim
99 Interstate
97 Bumble Bee
97 Red & White
tank_post142
south florida
February 15, 2012, 09:38:58 AM »
that "connection" appears to be the part of the switch that is normally closed and opens while the start switch is engaged.
I got a rock
VRCCDS0246
PharmBoy
Lawton, Ok
February 15, 2012, 09:43:09 AM »
Thanks!...Jim
99 Interstate
97 Bumble Bee
97 Red & White
