February 04, 2026, 05:15:39 AM *
Author Topic: Rear Brake Rotors  (Read 2013 times)
Rio Wil
« on: February 19, 2012, 09:18:03 PM »
Anyone know what  exactly is the difference(s) between the older and newer rear brake rotors.  I am in tereste4d in using a older rotor on a newer rear wheel....99 on a 01. What would need to be done to accomodate the rotor.......
Michvalk
Remus, Mi
« Reply #1 on: February 20, 2012, 01:31:42 AM »
I'm not positive, but I don't think there is any difference between 99 and 01. Cosmetic maybe. Difference is in the 97 rotor I believe.  cooldude
wdvalk
Katy Texas
« Reply #2 on: February 20, 2012, 02:35:42 AM »
offset is different starting in 99,bolts are different also
Rio Wil
« Reply #3 on: February 20, 2012, 07:36:08 AM »
OOPs....I meant a 98 on a 01 wheel.  So the question might more accurately be, if you have a rotor in hand, how can you identify it as to being a early or later rotor.
Rio Wil
« Reply #4 on: February 20, 2012, 08:42:09 AM »
Hhhmmmm.....it seems there are just two types of rear rotors.  An early model with non-recessed bolt mounting holes and a later model with recessed bolt holes. So if you are trying to buy a rotor from ebay, just determine if it has recessed or non-recessed mounting bolt holes to match your in-hand one....
RP#62
Gilbert, AZ
« Reply #5 on: February 20, 2012, 05:51:34 PM »
Here you go.
-RP
« Reply #6 on: February 20, 2012, 08:55:31 PM »
99 IS, and all models 2000 - 2003, use the newer one.
« Last Edit: February 21, 2012, 08:54:52 AM by gordonv » Logged
Rio Wil
« Reply #7 on: February 20, 2012, 09:06:19 PM »
OK....Thanks, think I got it now.  Not to nit-pick, but the late model rotors do have a undercut of .020 inch  as can be seen in the below pic's.
Thanks All
