May 02, 2026, 05:55:29 AM *
Author Topic: Installing chrome transmission covers  (Read 1462 times)
WDAN
Irving, TX
« on: February 20, 2012, 01:51:35 PM »
NEVER MIND. 9After three days of jacking with this, I got bolt holes to line up) It is embarrassing to admit my ineptness when it comes to wrenching but I have been unable to re-attach the master cylinder  to the transmission housing. You have to mount one end of right angle bracket with the kit using the same bolt hole. I have tried to attach that end first which is no problem but can't get the holes on other end which mounts with the vertical bracket to line up so I can get it started. If I mount the two brackets on other end first, then, I cannot get the holes on the master cylinder bracket and the right angle bracket to align with the hole.
What if I just leave the master cylinder "floating" without re-mounting it to housing? Doesn't look like it would matter.
Any comments from those who have installed these covers?
I could always go back in and try to do it correctly when I go to a wrench party and have some help.
« Last Edit: February 20, 2012, 02:23:47 PM by WDAN » Logged
WDAN
Irving, TX
Red Diamond
Beaumont, Texas
« Reply #1 on: February 20, 2012, 03:01:16 PM »
I think I did a little pushing where the black bracket attaches to the master cyclinder bracket to get them to line up. (phew) Anyways, I finally got things lined up and as it turns out, I don't even like the darn things, taking them off. I sprayed the trans cover with undercoat and didn't help with the tin can sound it makes when starting or running. Both sides going out the door.
Tx Bohemian
Victoria, Tx
« Reply #2 on: February 22, 2012, 08:06:30 AM »
My bike had these on it when I bought it but they looked crappy due to pitting/peeling of the chrome.  And after a couple of times of R&R and being a major PITA to put back on I left it off.  IMO it looks better.
I also removed the sparkplug covers because it's another PITA to get to the plugs with these on.
Al
