February 04, 2026, 05:17:04 AM
Bearings
Topic: Bearings (Read 1405 times)
2step
Old Coal Miner
SE KY
Bearings
February 20, 2012, 02:03:56 PM »
How do you get the bearings out of the rear case, or should I just buy new ones for the new rear case???
Re: Bearings
February 20, 2012, 08:49:27 PM »
Rear case? Rear case of what? Engine, hub, clutch? There are many bearings around our bike.
Re: Bearings
February 21, 2012, 08:09:58 AM »
It probably would be a better alternative to simply get a new bearing for the case.
The chances of damaging the bearing trying to remove it from the case will be present and (damage) may go unnoticed until such time as it starts to make noise.
You don't want to have to tear into the motor to replace that bearing if you can help it.
Rio Wil
Re: Bearings
February 22, 2012, 08:54:13 AM »
Not sure what you are calling the "rear case", can you post a pic or be more descriptive?
