August 20, 2025, 08:49:48 PM *
Author Topic: I need a refresher course..................  (Read 1632 times)
Scooby
« on: February 22, 2012, 02:47:02 PM »
Its been waaaaaaay too long since I have been here, but here it goes.  If you do not want to get involved in a ENGINE OIL question please stop reading now!  My rememberer is not what it used to be, last year I did some research on oil here and landed on a Mobile 1 synthetic, but I do not remember which one?  I have been riding my '97 since '98, but back in those days it was called "red cap", then I used the Rotella synthetic for a few years until last year when I went back to the "I can't remember the cap color"!  I like to use a heavier oil when I can because we ride the most during the summer months, a little in the spring and fall, but the majority when it is hotter.  Thanks for helping the remembering challenged!  Oh, I did remember to write down the oil filter number, so I picked that up today!
Scooby
« Reply #1 on: February 22, 2012, 02:50:07 PM »
Most of whats talked about here is the Mobil 1 15-50 FULL synthetic. If i'm off base someone WILL chime in. 2funny RIDE SAFE.
« Reply #2 on: February 22, 2012, 06:12:14 PM »
Mobil 1 has gotten a bit more complicated in recent years. Look on the back of the bottle and look for a double circle. It has the API service ratings in the top half. If the bottom half says "Energy Conserving" don't use it. It has Moly in it and might cause the clutch to slip. The bottom half has to be blank in order to use it in a wet clutch engine. M 1"s high mileage is OK as are some of the truck oils.
F6Dave
« Reply #3 on: February 22, 2012, 07:17:29 PM »
Several years ago the cap on a Mobil 1 bottle indicated the weight.  Red was 15W-50 and green was 10W30, and there were some others I can't remember.  They stopped doing that, maybe because there are so many weights now that they ran out of colors!  Many still refer to the 15W-50 as 'red cap', and I think there's still some red on the label that indicates that particular weight.
FryeVRCCDS0067
Brazil, IN
« Reply #4 on: February 23, 2012, 12:30:01 AM »
Some of the auto parts stores around here carry motorcycle specific Mobil synthic oil. If I'm not running Rottella then that's what I run. It's pricey but I know it's safe.
Cliff
Manchester, NH
« Reply #5 on: February 23, 2012, 03:08:50 AM »
+1   cooldude  states on the bottle "Optimized wet-clutch performance" or something similar.
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil1_Racing_4T_10W-40.aspx
VRCC # 29680
« Reply #6 on: February 23, 2012, 11:00:19 AM »
I have used the 15-50 mobile one, (that used to have a red cap) for 100000 miles and still have the original clutch in good operating condition.  Nuf said.  Hoser   cooldude
« Reply #7 on: February 23, 2012, 11:26:11 AM »
What Hoser said and MGM has 242K+ miles original clutch.   For 6 years, I tugged trailers along behind on trips.
Mr.BubblesVRCCDS0008
« Reply #8 on: February 25, 2012, 08:00:15 AM »
I have  a 144,000 on a 2000 I/S mobil 1 15w50 syn. no problems.
The Anvil
Derry, NH
« Reply #9 on: February 25, 2012, 02:14:05 PM »
Indeed there is still red on the label.
