November 23, 2025, 09:46:22 PM *
Author Topic: Uh Oh, Rear Brakle Noise this morning:UPDATE  (Read 1451 times)
SpidyJ
Murrells Inlet
« on: February 23, 2012, 06:27:07 AM »
Feels like a pad or the whole caliper is loose.  Hope it ain't a bearing or something.
Onle feel it when I apply the brakes.
Just goe out of the shop for the Hydro Lok fix.
« Last Edit: February 25, 2012, 03:26:53 PM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
F6BANGER
Albuquerque NM
« Reply #1 on: February 23, 2012, 06:58:23 AM »
if it feels like the caliper is loose, it could be. Look to see if the caliper bolt is in place. The axel goes thru one area and another bolt goes thru the swingarm and keeps the bracket from spinning. Check that first. Its an easy visual.
« Reply #2 on: February 23, 2012, 06:59:39 AM »
Left rear wheel bearing.  Been there done that.   cooldude
SpidyJ
Murrells Inlet
« Reply #3 on: February 23, 2012, 07:03:16 AM »
Wheel Bearing at 29k?  What are they made out of? Plastic?
Peace,
johnnywebb
« Reply #4 on: February 23, 2012, 07:06:36 AM »
Mine went out a 38 thousand.  But it was 14 years old too.
« Reply #5 on: February 23, 2012, 07:13:39 AM »
Sorry for the crappy video, I was trying to capture the noise with a cell phone and still drive the bike without killing myself.
But....does yours sound anything like this did?  Not brake caliper......left rear wheel bearing shot.  Everytime I hit the brakes, it would sound like the rear end was chewing rocks.
Brake caliper noise?powered by Aeva
« Last Edit: February 23, 2012, 07:15:58 AM by BF » Logged
F6BANGER
Albuquerque NM
« Reply #6 on: February 23, 2012, 07:40:05 AM »
Good video, Im glad you didnt kill yourself.
I have never had a bearing problem. I have heard of them going bad but have never actually heard it. How long can you ride with a bad bearing. I know you should change it as soon as possible.
SpidyJ
Murrells Inlet
« Reply #7 on: February 23, 2012, 08:04:14 AM »
I'll keep you posted.  Band practice tonight.......won't get to it till this weekend.
What do I buy, a bearing and a seal?  How much?
Peace,
johnnywebb
bscrive
Ottawa, Ontario
« Reply #8 on: February 23, 2012, 08:25:54 AM »
My bike has only 31k and I have had to change the rear wheel bearings twice now.  First time was an All Bearings set.  Went back to Honda line this time.
sutterhome
« Reply #9 on: February 23, 2012, 08:51:24 AM »
jack it up and rotate tire, my 2 cents your making this harder, not to mention somewhat more dangerous than it needs to be.
« Reply #10 on: February 23, 2012, 09:08:21 AM »
That's exactly what I did after I got home from making that first video on the bike.  That confirmed the left rear wheel bearing was bad.
Left rear wheel bearing noise?powered by Aeva
btw.....the bike never handled bad, it tracked straight and there didn't seem to be any play in the wheel after I jacked it up.  However, the bearing was bad and needed replacing.  The only indicator was that awful sound coming from the rear when I applied the brakes.
SpidyJ
Murrells Inlet
« Reply #11 on: February 25, 2012, 02:50:14 PM »
OK IT WAS worn out rear BRAKE PADS!!
What would you do?  Would you tear into the rear wheel and replace the bearings now or wait??
Need all y'alls expert advice...........I think I should at least change the oil in the rear an clean/polish everything up?????????
I wanna ride, I wanna ride, I wanna ride, I wanna ride.............
Peace,
johnnywebb
« Reply #12 on: February 25, 2012, 06:42:44 PM »
I rode from Knoxville to Orlando and then out to Mesa, AZ. Over 2500 miles towing a 400 lb tent trailer with the left rear bearing making noise. It sounded pretty bad when I got home. The bearing fell out in pieces
Bugslayer
Lubbock, Texas
« Reply #13 on: February 25, 2012, 06:53:20 PM »
Just put in a new set of pads and ........RIDE!  cooldude
SpidyJ
Murrells Inlet
« Reply #14 on: February 26, 2012, 07:15:42 AM »
Thanks......I agree........can't live my life worrying about breaking down..... cooldude.
Peace,
johnnywebb
