February 04, 2026, 06:54:02 AM *
Author Topic: Rivco rotor covers - different collar?  (Read 1263 times)
Beer van Huet
Netherlands
« on: February 23, 2012, 11:26:54 AM »
Hello,
I want to ride without my Rivco rotor covers for a while.
I installed them many years ago and the instruction is gone.
I recall that there was a different (shorter) front wheel collar provided, but I'm not sure.
Can someone confirm that YES, I need to install a different collar when removing the covers. If not, can someone provide the exact size of the front wheel collar? That will help me out as well.
TIA,
Beer
« Reply #1 on: February 23, 2012, 11:31:20 AM »
If you're taking about just the thickness of a couple pieces of sheet metal, you can disregard having to come up with a new spacer.
The front end can handle that little bit of difference easily.
Beer van Huet
Netherlands
« Reply #2 on: February 24, 2012, 01:45:35 AM »
I agree that the handling part is negligible......at my bike it does make a difference.  If you take the rotor covers off using no adjustment whatsoever, the brake pads will grind against the disks. I must admit I have installed new pads and disks as well so there is less room for error. BTW I found my old OEM collar. Thanks for the reply and assistance.
« Last Edit: February 24, 2012, 01:48:52 AM by Beer » Logged
