Red Diamond
« Reply #1 on: February 23, 2012, 04:43:09 PM » |
Stanley, they are new and expensive. EMS Global also makes one or imports one from Japan, and you can get one from Pat's Small Engine or equipment Parts, I think. The GL1500 Goldwing alternator is pretty cheap from Pats, but the parts guy said they are from China. EMS Global says theirs is OEM not aftermarket, and the Goldwing version is a bit cheaper, just needs to be clocked for the Valkyrie. I'm still bumping my head on which one to go with. I have a Tourer to ride, so am in no hurry. The rebuilt one I purchased October of 2010 crapped out this past January, so the next one will be new.
« Reply #2 on: February 23, 2012, 04:47:36 PM » |
Thanks again for the information Steamer
Stanley Steamer
« Reply #3 on: February 23, 2012, 04:53:04 PM » |
I was NOT thrilled (when after a real PIA change out) the newly rebuilt one made a whirring noise......  I was told...... "Sometimes the air diverter inside bends a little, it is very close tolerance and it makes contact with the cooling fan blades, it will wear down. No serious problem."It still makes that noise...
Stanley "Steamer" "Ride Hard or Stay Home"
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #4 on: February 23, 2012, 05:03:53 PM » |
I got the 85 amp. Hitachi off E-Bay for $190.00 plus 20 shipping. So far it charges great and makes no more noise then my old one which I plan on having rebuilt to 85 amps.
  If guns kill people where are mine hiding the bodies
eric in md
« Reply #5 on: February 23, 2012, 05:04:11 PM » |
:tickedoff:i had three alt from mars to made that noise.. ken did take care of me 100% hope i got a good and quiet one now.
Stanley Steamer
« Reply #6 on: February 23, 2012, 06:09:26 PM » |
:tickedoff:i had three alt from mars to made that noise.. ken did take care of me 100% hope i got a good and quiet one now.  3????.......I hated changing it out ONCE!!
eric in md
« Reply #7 on: February 23, 2012, 06:12:52 PM » |
yep in 3 thousand miles to boot . 3 in 3 weeks not fun ... but ken did take care of me ..
Stanley Steamer
« Reply #8 on: February 23, 2012, 06:16:40 PM » |
Did you keep changing it out because of the noise??......it would seem to me that he could hear that noise when he tests them out??......
Charlie McCready
« Reply #9 on: February 23, 2012, 06:18:54 PM » |
I had to replace the alternator on my '97 Valk a few years ago. I bought the 1500 Gold Wing alt. Cheaper and all ya need to do is take the three case bolts out and index it one bolt hole. Worked for me !!
lucky_1_chris
« Reply #10 on: February 23, 2012, 06:21:55 PM » |
My rebuilt from MARS whirs, but it works fine. The noise doesn't really bother me, but it doesn't give me confidence, either. I'm going to buy a spare to carry with me on trips this summer.
1999 Valkyrie Interstate
Stanley Steamer
« Reply #11 on: February 23, 2012, 06:23:04 PM » |
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« Reply #12 on: February 23, 2012, 07:00:22 PM » |
If MARS knows about the whine, why don't they do something about it? Or is it just some and not all? I would appreciate an honest answer.
hillbilly
« Reply #13 on: February 23, 2012, 07:02:15 PM » |
EMS Global in Logan WV 12 miles from my home $277.00 in 2010 New not rebuilt, no core charge.
Stanley Steamer
« Reply #14 on: February 23, 2012, 07:23:37 PM » |
eric in md
« Reply #15 on: February 24, 2012, 04:41:10 AM » |
Did you keep changing it out because of the noise??......it would seem to me that he could hear that noise when he tests them out??......  yep making way to much noise for me.
« Reply #16 on: February 24, 2012, 04:45:01 AM » |
While it may be more expensive, I'd rather go this route than a rebuilt that whines. It just not woth the constant concern/worry and wondering. Put the new one in, have your old one rebuilt at a reliabe shop and ride on with life. I've not changed out the alternator on a Valk yet but, I am not really looking forward to it either.
VRCC# 29981 Learning the majority of life's lessons the hard way.
Charlie McCready
« Reply #17 on: February 24, 2012, 06:08:31 AM » |
" Put the new one in, have your old one rebuilt at a reliabe shop and ride on with life."
I tried this at a local shop. They said they weren't able to get parts for them. Who rebuilds them??
larswlvs
Akron,Ohio
« Reply #18 on: February 24, 2012, 09:04:03 AM » |
They would not be that hard to rebuild yourself, just clean it up and replace the brushes and bearings.but if your having it rewound then you have to take it to a pro.
Red Diamond
« Reply #19 on: February 24, 2012, 09:13:52 AM » |
Just talked to a rep at EMS Global, told me the Goldwing and Valkyrie alternators are the same, just difference in price and both made by Hitachi, not an aftermarket. Of course, there is the clocking that has to be done for the Valkyrie and vice versa for the wing. The LR140-708C, $228.00.
F6BANGER
« Reply #20 on: February 24, 2012, 09:28:45 AM » |
I just talked to a local place here in Alb and just asked Questions. Mine is still going good. He said he could rebuild mine for $60 to $100. I also asked if mine went out if he could rebuild it to put out more juice. They can. I asked if I needed a heavier duty battery and he said no. HMMMMM ??? I told him I took the cover off every so often and blew compressed air in it to clean out all the dust and dirt. He said it was a good idea. That makes it run cooler. Heat is what kills them. Hopefully mine lasts forever and I will never have to find out.
Stanley Steamer
« Reply #21 on: February 24, 2012, 10:00:19 AM » |
My old alternator was still working fine at around 75K.....but I thought I could hear a faint noise as though a bearing might be going out....hate that the rebuilt one makes this noise.....I would think that anything touching in there would generate heat which probably isn't good either.....
F6BANGER
« Reply #22 on: February 24, 2012, 10:13:46 AM » |
Way back when, just out of high school I used to rebuild starters and alternators/generators. So I know a little bit about them. The brushes rubbing the commutator wear and the dust coats things. That insulates it and holds in heat. You need to undercut the mica as the commutator wears down. That too helps with temperature.
But that was many years ago. My rememberer doesnt work as good anymore.
« Reply #23 on: February 24, 2012, 01:09:17 PM » |
THAT'S NOT A BAD PRICE.
IT'S ALOT HIGHER AT HDL:
ALTERNATOR ASSY. 31100-MBY-005 001
List Price $648.87 Selling Price $453.24
