February 04, 2026, 05:16:54 AM
Replace rear brake pads
Topic: Replace rear brake pads (Read 1874 times)
bigguy
VRCC# 30728
Texarkana, TX
February 23, 2012, 05:50:22 PM »
Pages 15-7 and 15-8 in the manual shows the procedure. Do I understand correctly that you do not remove the caliper to replace the pads?
Here there be Dragons.
Joe Hummer
Arnold, MO
Re: Replace rear brake pads
February 23, 2012, 05:56:14 PM »
That is correct. I use a large screwdriver to open the pads up as far as i can. You take loose the screw cap, then remove the pin under the cap. The pads will pretty much fall out. Then install the new pads, insert the pin, and the cap. Make sure you pump the brakes before taking it for a ride.
Joe
1999 Valkyrie Interstate
bigguy
VRCC# 30728
Texarkana, TX
February 23, 2012, 06:43:45 PM »
Thanks Joe. I'll get er done tomorrow.
CASABROKER
February 23, 2012, 07:16:27 PM »
If the srew is stuck use an impact driver on it be careful not to strip the head.
tank_post142
south florida
February 23, 2012, 09:22:41 PM »
then coat the screw with anti-seize
I got a rock
VRCCDS0246
