August 20, 2025, 08:50:47 PM *
Author Topic: No Dipstick markings, need measurement.  (Read 2009 times)
whitestroke
San Pedro, Ca.
« on: February 23, 2012, 10:52:30 PM »
My Valk I just purchased has no dipstick.  Just a temp. gauge with a long probe. I want to file some marks in it tat the proper level (hi-low) .  Can someone measure there marks for me?    angel   It would be much appreciated.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Beer van Huet
Netherlands
« Reply #1 on: February 24, 2012, 01:29:30 AM »
I did the same with mine. The temp dipstick is longer than the OEM one, so I measured the original from the beginning of the thread to the marks.
Full= 21 cm
Low= 22,2 cm
Measurement may not be rocket science, but you can look for yourself.
« Last Edit: February 24, 2012, 01:34:05 AM by Beer » Logged
Bone
« Reply #2 on: February 24, 2012, 03:41:52 AM »
Beer that is the first metric ruler I have ever seen. The rest of the world has it so easy.
In the US we are bi/everything. Speed, weight, distance and sex just to name a few.
« Reply #3 on: February 24, 2012, 04:32:58 AM »
Wouldn't one way be to properly change the oil and just add 3 qts then mark the stick, add the 4th qt and remark the stick..
Beer van Huet
Netherlands
« Reply #4 on: February 24, 2012, 05:20:32 AM »
Hi Patrick,
There are many ways but that was not the question Smiley
« Reply #5 on: February 24, 2012, 05:25:13 AM »
if this is what u have http://www.teltru.com/c-34-motorcycle-and-atv.aspx
it already has marks on it. u need the instructions that came with it. it might be on their site or give them a call, their customer service is excellent.
whitestroke
San Pedro, Ca.
« Reply #6 on: February 24, 2012, 05:58:11 AM »
Thanks Beer! It;s not the Tru Temp. It's 2 bros racing.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
longrider
Vernon, B.C. Canada
« Reply #7 on: February 24, 2012, 07:32:18 AM »
The Valk takes exactly 4 quarts for an oil change.  Easiest thing to do is give her a oil change w filter and start her up for a few minutes.   Shut down and Give the oil time to get back to the crankcase, stand her up and pull the stick.   Mark it at that level.  your good to go.
« Reply #8 on: February 24, 2012, 09:29:52 AM »
to be exact from the tech manual
oil capacity is 3.9 quarts or 3.7 liters with an OEM filter.  4 quarts will be overfilled.
3.9 quarts is 124.8 fluid oz   4 quarts is 128 fluid oz
« Reply #9 on: February 24, 2012, 09:44:52 AM »
Bah... I hate bi rulers. You're building something? Need to compare this to that? Measure
this in inches, turn around to measure that and now you're reading centimeters...
-Mike "heavy duty pet peeve..."
Thespian
Bonny lake Washington
« Reply #10 on: February 24, 2012, 10:10:21 AM »
 I did my first oil change couple months back. leaned the bike over to the right about as much as it is on the side stand, do drain as much oil as I could. Used my cycle lift. took 4 qt to fill her back to the top line.
« Reply #11 on: February 24, 2012, 11:38:50 AM »
The Valk actually takes about 4.5 qts but generally about a 1/2 qt stays in the case.. If you raise the front a bit and lean it to the right about 4 1/4 qts will come out.. But, this is getting picky, but, some like picky..
« Reply #12 on: February 24, 2012, 02:31:43 PM »
yes for us being picky, per the manual 4.3 liters or 4.5 qts at disassembly of engine. normal oil change is in my earlier post.
RP#62
Gilbert, AZ
« Reply #13 on: February 24, 2012, 03:59:20 PM »
I've got a TBR temp gage / dipstick on mine and it has a line scribed on it that coincides with the full mark on the stock stick.  Its tought to see, but its there.
-RP
whitestroke
San Pedro, Ca.
« Reply #14 on: February 24, 2012, 09:54:52 PM »
For you non-bi's it's   8 1/4  to  8 3/4       Roll Eyes
Thanks again Beer
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
