January 28, 2026, 06:27:02 PM *
Author Topic: Kewl Metal Bleed Feed Air Ride System  (Read 2354 times)
rbert
« on: May 14, 2009, 01:14:58 PM »
Has anyone tried this air shock system? How do they Rate?
Bagger John - #3785
« Reply #1 on: May 14, 2009, 03:36:59 PM »
Looks interesting. I may have to order one for my VTX in the near future.
I'm in the process of building my own system for my "slammer" I/S, based on an '83 GL1100A compressor/drier/air piping, an NOS purge valve for the "bleed" side and a Stewart-Warner HDX-series electrical air-pressure gauge. Shocks are Progressive 416s; obtained from a VRCC member. These are now on the bike, and I'm plumbing the air lines next. The compressor/drier assembly will mount in the fairing and I'm going to use the rubber compressor/drier enclosure from an '84 GL1100A to hold everything in one nice little package.
The air pressure gauge and a matching coolant-temp gauge will be mounted in the radiator pods, and a modified Big Bike Parts master cylinder switch housing will provide controls for fill/vent and compressor actuation, in addition to an accent lighting circuit.
Pics as the installation progresses. I was lucky to have most of the stuff I needed for this on-hand, and only needed to buy the shocks, an air-line adapter, a few fittings, the gauges and the purge solenoid.
franco6
Houston, TX
« Reply #2 on: May 26, 2009, 09:21:06 PM »
pgressive 416 work like a dream. got lucky piked up on e-bay for a song
Enjoy the ride!
