February 04, 2026, 08:44:53 AM
CB error
Topic: CB error (Read 1276 times)
eddie
CB error
February 29, 2012, 06:21:28 PM »
1999 Interstate Trike I just bought is showing Er on the display when I try to switch the function switch to CB. Any ideas??
sugerbear
wentzville mo
Re: CB error
February 29, 2012, 06:24:52 PM »
uplug and replug the large plugs under the seat. clean it if it looks dirty, add some dilectric grease.
also, if it's been wet let it dry, then do the above.
eddie
Re: CB error
February 29, 2012, 07:31:17 PM »
Thanks Sugerbear, been thru your town several times on my may to Troy and Moscow Mills. Have some X-inlaws living there.
PhredValk
Edmonton, Alberta, Canada
Re: CB error
February 29, 2012, 07:55:54 PM »
I don't mean any insult, but does it have a CB? Mine doesn't and I get the same thing if I go to CB on the controller. Not all Interstates came with CB as it was an option.
Fred.
VRCCDS0237
Novavalker
99 Interstate/2017 Goldwing
Re: CB error
March 01, 2012, 02:05:41 AM »
Have a look at this thread.
http://www.valkyrieforum.com/bbs/index.php/topic,33947.0.html
Re: CB error
March 01, 2012, 08:37:32 AM »
You can look under the tour pack and see the CB unit, if indeed you have a CB. It's right up under there, a black box.
You'd have an antenna also, separate from the radio antenna.
sugerbear
wentzville mo
Re: CB error
Reply #6 on:
March 01, 2012, 06:42:03 PM »
Quote from: eddie on February 29, 2012, 07:31:17 PM
gimmy a heads up next time ill buy you a tea...or somethin..
went to H/S is troy, and partied in moscow
