February 04, 2026, 08:43:59 AM *
Author Topic: HOW MUCH BRAKE FLUID?  (Read 1382 times)
WDAN
Irving, TX
« on: March 02, 2012, 07:59:56 PM »
I need to know how much DOT 4 to buy to change out all of my fluid (brakes & clutch)
WDAN
Irving, TX
Mr.BubblesVRCCDS0008
« Reply #1 on: March 02, 2012, 09:43:18 PM »
I would think a quart would be enough. Are you gonna use a mighty vac or do the pump the brake type bleeding.?
« Reply #2 on: March 03, 2012, 03:51:47 AM »
Or get three or four pints, so that any left over won't be open...
WDAN
Irving, TX
« Reply #3 on: March 03, 2012, 05:00:01 AM »
Thanks guys,
I already had a 16.9 oz bottle of SILKOLENE DOT 4 and purchased 3 - 12 oz bottles of Prestone. Probably OK to mix the brands but I will likely keep them separate.
Going to a friend's to help me. He has a motorcycle garage in back yard where he keeps and works on his several antique motorcycles. Don't know if he uses a pump or not.
WDAN
Irving, TX
Cattman
Franklin, IN
« Reply #4 on: March 03, 2012, 06:49:36 AM »
Just did mine with speed bleeders using the pump method. 1 quart bottle used with a tiny bit left to toss.
WDAN
Irving, TX
« Reply #5 on: March 03, 2012, 07:53:24 PM »
I ended up using a 16.9 oz bottle for front and back brake lines and clutch and had, at least, 1/4 of bottle left. Thought it was going to take more.
WDAN
Irving, TX
