August 15, 2025, 06:16:56 PM *
Author Topic: Final Drive Gear Oil?  (Read 1448 times)
buzz
« on: March 04, 2012, 11:53:22 AM »
I'm due to replace my final drive gear oil.  Would like to switch to Mobile-1 75W-90 Synthetic Gear Lubricant.  Should I do it or should I stay with the original Hypoid Gear Oil SAE-80?
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #1 on: March 04, 2012, 12:01:12 PM »
I use it, runs cool, no issues. That said, I use Mobil synthetic in most of my vehicles.
paps350
Pittsburgh Pa
« Reply #2 on: March 04, 2012, 01:45:26 PM »
I also use synthetic 70W/90W no problems.
Mr.BubblesVRCCDS0008
« Reply #3 on: March 04, 2012, 02:44:39 PM »
I've got 145k on my bike syn mobil gear oil all the way.
Tropic traveler
Silver Springs, Florida
« Reply #4 on: March 04, 2012, 05:48:55 PM »
Mobil 1 synthetic in all 3 Valks.  cooldude
'13 F6B red for Kim
buzz
« Reply #5 on: March 04, 2012, 06:33:21 PM »
OK, wasn't sure.  Mobil it is.  Thanks
WDAN
Irving, TX
« Reply #6 on: March 05, 2012, 06:37:37 AM »
I use Royal Purple synthetic but I am sure they are all good.
WDAN
Irving, TX
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #7 on: March 05, 2012, 03:09:09 PM »
I use  Mobil-1 75W-90 Synthetic. I change it every other oil change.
« Reply #8 on: August 17, 2012, 08:17:38 PM »
Has anyone used super tech synethic gear oil. Saw it at walmart tonight. Wasnt sure about it so went to advanced auto and picked up mobil 1.
« Reply #9 on: August 17, 2012, 08:48:33 PM »
no matter what you use make sure its hypoid rated.  Theres just a few drops in there gotta be right
« Reply #10 on: August 17, 2012, 09:04:38 PM »
I've used Amsoil 75w 90 for the last 60,000 + miles with no issues.
I change it with every other rear tire change, which is probably overkill.
« Last Edit: August 17, 2012, 09:06:14 PM by 3fan4life » Logged
« Reply #11 on: August 17, 2012, 11:41:37 PM »
Any synthetic in that grade will work for at least 20K, if not 30K miles easily if you drive more per year.
I changed mine last year for the first time guessing since 2001 when I/S was new from previous owner and after  10 years and about 22K, the oil was pretty gunky and dirty with some sludge on the oil drain plug, definitely needed to be changed after 10 years though.
