November 23, 2025, 08:47:27 PM *
Author Topic: Final Drive drain & fill plugs  (Read 1323 times)
amazngrace
Eastern Shore, Virginia
« on: March 07, 2012, 11:23:19 AM »
I was recently servicing a new-to-me Ford Explorer and when I was checking around on
the Explorations forum, I was reminded of something that would be of  great use to
anyone doing final drive oil. (and, yes, I need the occasional reminder)
"Never remove the drain plug first"   If you drain and then can't get the fill plug off,
you are "HAD" big time!
..ED
« Last Edit: March 07, 2012, 11:25:11 AM by amazngrace » Logged
99 Red and Black IS
« Reply #1 on: March 07, 2012, 12:00:53 PM »
This is a very unecessary precaution.  The easiest way to service the final drive is when its OFF the bike.  That way you dont get oil all over the tire and exhaust.  if you drain it well and pour in exactly 150cc you dont have to see it overflow to know you have the RIGHT amount.
Cheers
amazngrace
« Reply #2 on: March 07, 2012, 01:24:25 PM »
Thanks Chris, That is my backup plan if I can't get the fill plug out.
I will generally change the fluid when I flush the brake and clutch lines, but
I've been thinking of adding the spline/pinion/ etc. check and service to the
fluid interval.
..ED
99 Red and Black IS
« Reply #3 on: March 07, 2012, 02:38:24 PM »
fluid interval.
..ED
"back-up plan"  Ive been doing this for 10 years now and I can tell you by far its a better plan A to use synthetic hypoid gear oil, it will last 10,000 miles or the life of your tire whichever you use as a rear service interval.  Everytime the back wheel comes off you should R/R the drive shaft for lube.........so..........change the final drive oil every time you lube the drive shaft.........
« Last Edit: March 08, 2012, 05:41:09 AM by Chrisj CMA » Logged
RP#62
Gilbert, AZ
« Reply #4 on: March 07, 2012, 04:55:30 PM »
I can also tell you that you shouldn't put the oil in until AFTER you've put the drain plug back on.  I've tried it both ways and putting the drain plug in first worked out much better.
-RP
« Reply #5 on: March 07, 2012, 05:20:55 PM »
-RP
LOL.........well, I guess thats right.
« Reply #6 on: March 07, 2012, 07:11:48 PM »
Cheers
Except when the only 150cc measuring cup you have is the wife's baking Pyrex, and she smacks you with the rubber mallet.  I only spill a few drips with my method (if any), and avoid the rubber mallet.   Grin
« Reply #7 on: March 07, 2012, 09:48:27 PM »
Local Princess Auto (Harbor Freight) has a large syringe, comes on sale for $.99 sometimes, I use mine for topping off the water in my battery. Goes right in the hole, not a spilled drop.
Will buy another for oil. Works in any direction and can pre-measure.
« Last Edit: March 07, 2012, 09:54:02 PM by gordonv » Logged
9Ball
« Reply #8 on: March 08, 2012, 02:27:04 AM »
I change the gear oil every other oil change....cheap, easy, and quick.
YMMV
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
