March 29, 2026, 09:30:39 PM *
Author Topic: salvage or wrecked yards where are they  (Read 1005 times)
roadmap
« on: March 07, 2012, 11:38:01 AM »
i am in need of a engine with low miles
my bike with 155000 has #2 cylinder no or little compression
did a carb rebuild new slow jets a good cleaning
did the spark test nice and blue spark gas getting to the carbs
just won't fire on #2 could be still clogged not sure
so now where are the junk yards???
most of the auctions place want a couple hundred just to bid.
i know about pinwalls not sure if i want to spend that kind of money on just a engine
engines are the hardest to sell they never go bad or do they
any help locating a parts or salvege yard would be helfull
The Anvil
Derry, NH
« Reply #1 on: March 07, 2012, 11:39:20 AM »
I guess the obvious question is; why can:t you just fix yours?
Momz
ABATE, AMA, & MRF rep.
« Reply #2 on: March 07, 2012, 12:18:31 PM »
I find it hard to believe that at 155K that #2 cylinder is shot.
Did you check that the valves are properly adjusted?
If you find a salvage motor, can I have your current motor?
ALWAYS QUESTION AUTHORITY!
tank_post142
south florida
« Reply #3 on: March 07, 2012, 02:14:06 PM »
is there an echo in here?
I got a rock Sad
VRCCDS0246
czuch
vail az
« Reply #4 on: March 07, 2012, 02:35:05 PM »
HELLOOOOO,,,,helloooo,,,,,,,,,,,,helloooo
BOB'S in Phoenix,  Az.
I see em on the bay site. Pinwalls?
« Reply #5 on: March 07, 2012, 02:36:23 PM »
Pinwall's prices are probably about as good as you're going to find for salvage yards.
You may be fortunate enough to find an individual who'll turn over his extra motor for under $500, but that would be rare.
Phil57
Jenison MI
« Reply #6 on: March 07, 2012, 03:53:45 PM »
John Schmidt has one for sale. Your parts and his should make one good motor.
hager the horrible
florence co
« Reply #7 on: March 07, 2012, 05:42:27 PM »
I would do a compresion test on #2 cyl if you put another engine in and transfer your carbs and such you could still have a dead #2 cyl
art
Grants Pass,Or
Grants Pass,Or
« Reply #8 on: March 07, 2012, 07:54:40 PM »
Probably only needs a valve job.It's very easy to pull the heads an check an replace or regrind the valves .If you regrind total cost would be less than$200.I did it to my valk.I lapped the valves had the heads surfaced and new head gaskets.Piece of cake.
