November 23, 2025, 08:47:41 PM *
Author Topic: Starter Button MX  (Read 1240 times)
« on: March 08, 2012, 01:15:39 PM »
Well, Im out getting stuff for dinner at the store and I get on the bike to come home.
Key- on
Neutral light- green
Starter Button- Nothing....not a clic, not a clunk not a anything.
So, Im always telling myself......."Self, anything funny during starting and you let off that button fast!"    Well since NOTHING happened Im not thinking hydrolock (and IT WASNT)  So I check the first culprip
Kill Switch-its in run
Neutral light- double check green
This time I pull the clutch in even though I shouldnt have to and she starts right up.  Hmmmmm.  So I turned it off and tried it again with no clutch....NO START, so Im thinking clutch switch.  Then I pulled the clutch in and it still wouldnt start.  Hmmmmmm.  So now that I know its not locked I left the clutch alone and just hit the starter and no start but I jiggled the start button and sure enough she started.  I knew right then it was the contacts inside the starter switch housing.
When I got home and took it apart the little tits in there had a black film and they were jammed down in the carrier.  This switch was only two years old too.
So I pulled the contacts out and stretched the spring a bit, lubed the ears of the contact that goes into the plastic carrier with dilactic grease, and voala the little titties went bouncy bouncy like they are supposed to.....(its always good when they do that isint it)  A little  more dilactic on the contacts after getting them all clean and snap it all back together and its like new.
I think them contacts were jammed from new and that caused a weak contact on the little pads and then the black stuff.
So when you do the button maintenance make sure they go bouncy bouncy....its always a good thing  Cheesy
« Last Edit: March 08, 2012, 01:18:14 PM by Chrisj CMA » Logged
BonS
Blue Springs, MO
« Reply #1 on: March 08, 2012, 03:14:50 PM »
Probably not what you were expecting in the Tech Section . . .  Cheesy Cheesy Cheesy
« Reply #2 on: March 08, 2012, 03:33:51 PM »
See, its always a good thing
junior
new hampshire
« Reply #3 on: March 08, 2012, 03:37:08 PM »
hey chris, dont under estimate that kill switch, mine was doing the same thing as you discribed, i did the switch maintainance and it still messed up, come to find out that the kill switch was toast. i never used it so i bypassed it
Dave G
Born in the USA July, 1996
La Porte, TX
« Reply #4 on: March 08, 2012, 06:04:33 PM »
The kill switch is there for emergency shutdown not daily use.  It is very impoortant to have it.
I am proud to be a "Valkyrie Fundamentalist".
« Reply #5 on: March 08, 2012, 06:21:17 PM »
Chris, while you're at it, why don't you install the bypass relay to take the major amp load off that start switch?
The procedure is about halfway down; Start Switch Safeguard.
http://www.rattlebars.com/mtz/starter.html
« Last Edit: March 08, 2012, 06:23:13 PM by John Schmidt » Logged
« Reply #6 on: March 08, 2012, 08:02:58 PM »
I have had my Valkyrie for ten years and 130K miles.  Were doing alright how we are
« Reply #7 on: March 08, 2012, 08:30:03 PM »
That's good. Where do you think the "black stuff" you referred to came from?  It's usually caused by arcing from high current.
