99tourer
« on: March 10, 2012, 05:18:32 AM » |
Have just carried out a carby clean . It seems to run ok without load but once on the road the engine just dies. Anyone have any suggestions
« Reply #1 on: March 10, 2012, 05:34:09 AM » |
Need more info. List what you did, maybe someone will spot something.
« Reply #2 on: March 10, 2012, 05:43:57 AM » |
- cracked vacuum lines (especially the one to the petcock)
-kinked vent hose
-intake tubes not fully connected
-out of gas (between normal and reserve)
Who knows......like has been said more info
justooneez
« Reply #3 on: March 10, 2012, 08:05:34 AM » |
Possibly a partial kink in the fuel line as well, let us know some more info, did you add anything (fuel filters, new gaskets and orings, and how much did you dig into on your carb clean)
Mr.BubblesVRCCDS0008
« Reply #4 on: March 10, 2012, 08:37:18 AM » |
Petcock diaphram not opening completely maybe?
« Reply #5 on: March 10, 2012, 09:26:59 AM » |
As everyone said, not much info.. But, I think I'd take a look at what you did, it may be in there somewhere.. Overall, it appears like a fuel delivery issue, such as, vacuum line, petcock, vent line, fuel line, etc..
Grumpy
« Reply #6 on: March 10, 2012, 11:20:20 AM » |
Try leaving the fuel cap slightly open, if the problem goes away, you have a kinked vent hose.
Blackduck
« Reply #7 on: March 10, 2012, 07:41:08 PM » |
What was the bike running like before the carbi clean? The reason for the carbi clean? By clean I take it you had the carbs off and a full strip down.
« Reply #8 on: March 11, 2012, 04:56:43 AM » |
I guess its not that important ???
99tourer
« Reply #9 on: March 12, 2012, 02:24:18 AM » |
Checked it again the following day and can't get it to rev much over 3500 (stationery) before it starts to drop away. Had fuel go off. Will pull the carbs again.
99tourer
« Reply #10 on: March 12, 2012, 02:28:15 AM » |
The carbs were fully stripped but I think the fuel may have gone off since. I will pull them again and check. I now starts to run out of puff at around 3500 rpm stationery.
Blackduck
« Reply #11 on: March 12, 2012, 03:51:54 AM » |
Sounds like super lean mixture, is the airbox stock? Not missing the foam pad in the intake section odf the top cover? Other than that are the rubber inlet tubes from airbox on correctly? Also check all the hoses under the airbox are hooked up, any air entering into airbox other than the the standard inlet will cause a lean condition and low maximum RPM. How was the bike running before stripping the carbs?
Cheers Steve
« Reply #12 on: March 12, 2012, 05:51:49 AM » |
Seems to me a good possibility of a petcock problem, not getting much feedback from you, have you checked or rebuilt it? That is an easy fix if it's the problem. We need more info than you seem willing to give? Hoser
« Reply #13 on: March 12, 2012, 05:55:48 AM » |
It is common to either break a tube or get a tube from the back side of teh carb to the airbox NOT on all the way so its sucking air. Bat senses say look with a flashlight and a mirror before and after install to make sure all is TIGHT. You dont need to be adjusting the carburators to try to compensate for open air sucking connections in there
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #14 on: March 12, 2012, 09:34:10 AM » |
If you added a fuel filter and did not cut off some of your fuel line you made your fuel line longer by the length of your filter and you may have a kink in the fuel line
  If guns kill people where are mine hiding the bodies
99tourer
« Reply #15 on: March 12, 2012, 04:57:11 PM » |
Seems to me a good possibility of a petcock problem, not getting much feedback from you, have you checked or rebuilt it? That is an easy fix if it's the problem. We need more info than you seem willing to give? Hoser  The fuel valve was replaced with a Pingel. I have gone back to the drawing board I think the fuel may have gone off again.
Blackduck
« Reply #16 on: March 12, 2012, 07:10:27 PM » |
I doubt the fuel has gone off that bad that it will not run, how long has the fuel been in it? Still would like to know how the bike was running before you did the carbs and how long has the bike been sitting after the carb work. Did it run properly after the carb work and then start to play up?
99tourer
« Reply #17 on: March 12, 2012, 07:40:45 PM » |
The carbs were originally pulled owing to bad fuel . It then sat for a few months after the carb work was done. I am in Australia and fuel going off is a real problem. I think we finish up with all the fuel no one else wants.
99tourer
« Reply #18 on: March 12, 2012, 07:47:46 PM » |
Sorry for the delay . I am new to this board and wasn't sure how to reply. I now thinking that I have an issue with bad fuel. It now starts to run out of puff around 3500 Rpm while stationery. I will pull the carbs again and possibly fit a Desmog kit while I am at it.
Blackduck
« Reply #19 on: March 13, 2012, 03:59:07 PM » |
Your area is not listed in your profile, I am in Aus as well and have no issues with fuel. Have you been using E10? Cheers Steve
