November 23, 2025, 09:49:59 PM *
Author Topic: front wheel bearings?  (Read 1647 times)
jdh
« on: March 10, 2012, 07:53:38 AM »
Can anybody tell me the size of front wheel bearings to a 99 I S and to a 97 standard i know the 97 are a bit smaller
thank you
fatboy
Mr.BubblesVRCCDS0008
« Reply #1 on: March 10, 2012, 08:39:45 AM »
6204 sealed on both sides.   Shop talk  has all of this type imfo. on Jeff Ks page. cooldude
« Reply #2 on: March 10, 2012, 08:41:19 AM »
The 6204 is for the 99. THe 97 is smaller but that imfo. is there too.
« Reply #3 on: March 10, 2012, 08:42:42 AM »
One more time the 97 is 6004 also sealed on both sides.
jdh
« Reply #4 on: March 10, 2012, 09:13:56 AM »
I need to know how much difference there is in actual size
thank you
« Reply #5 on: March 10, 2012, 01:18:37 PM »
thank you
Enough that they will not inner change if that is what you are thinking on doing.
I don't have my dial indicator here at the house.   Don't know if I have a 98 up front bearing at the shop either, I know I have a 97 on the shelf.
jdh
« Reply #6 on: March 10, 2012, 05:14:16 PM »
sent my wheel in to chrome  the bearings i have way to big to fit wheel i got back must be 97 not just clean chrome out to big
Disco
Republic of Texas
« Reply #7 on: March 10, 2012, 07:00:24 PM »
This seems to be a problem with (some?  all?) chrome wheels, but that's another discussion.  Bottom line is whatever you do to remove enough mess to allow installation of the correct bearings, DO NOT remove so much that the bearing cup is too big.  A buddy of mine with a chrome wheels (front is no longer on the bike) originally suspected a bad tire, then suspected bad bearings.  While we were at a wrench party and he was doing something else, I pulled the front wheel to inspect and the bearings came out in my hands with no need for a puller.  We don't know if it was the previous owner or the chromer who realized he'd effed up, but the honing to correct went too far and the wheel is now a shiny piece of junk.  He now suspects the rear wheel has the same problem.  We'll know at the next service interval.
The 6004 bearings (stock '97 fronts) are 42mm in diameter, 12mm wide, and the axle hole is 20mm.
The 6204 bearings (stock for all non-97 fronts) are 47mm in diameter, 14mm wide, and the axle hole is 20mm.
« Last Edit: March 10, 2012, 07:06:18 PM by Disco » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
jdh
« Reply #8 on: March 11, 2012, 06:46:56 AM »
Thats what I needed to know I got a 97 wheel back no problem will get 97 bearings
Thank you for all your help
fatboy
Tx Bohemian
Victoria, Tx
« Reply #9 on: March 14, 2012, 05:34:42 AM »
Just a thought...
Would it be possible to put a '98 or later frt wheel on a '97?
Is it just the brgs sizes on the 97s that are different than the rest, or other factors like axle diameter, brake mounting, fork mounting ...
Or is this not that big of an issue with the '97s?
Just curious, I have a '99.
Al
jdh
« Reply #10 on: March 14, 2012, 11:20:48 AM »
I was told that only diff in the wheels is the outer size of the bearing every thing else is same just use 97 bearings
Earl in Pensacola
« Reply #11 on: March 14, 2012, 08:35:30 PM »
I changed my OEM frt bearinga at 85K, "just because" they were at 85K!  Now the bike, a '97 tourer,  has 248.8K and still on that second set of OEM bearings. The fact that the bering is a little smaller doesn't seem to make a difference.   JMHO
