November 23, 2025, 09:50:15 PM
shifter seal
Topic: shifter seal (Read 1495 times)
eRaGoN
shifter seal
March 11, 2012, 09:45:28 AM »
traced the oil leak at the shifter seal, anyone has the right part number? TIA.
custom1
01 Interstate
SW Pa
Re: shifter seal
March 11, 2012, 09:56:27 AM »
#25 in the "shift drum @ shift fork" diagram. 91206-286-013
http://www.hdlparts.com/fiche_section_detail.asp
John
Bugslayer
Lubbock, Texas
Re: shifter seal
March 11, 2012, 10:15:28 AM »
I just picked up my new seal yesterday. If the garage warms up, I'll install it later this afternoon.
Algonquin Highlands, Ontario Canada
Re: shifter seal
March 11, 2012, 10:22:06 AM »
Quote from: Bugslayer on March 11, 2012, 10:15:28 AM
Do you have to drain the oil to do this?
Re: shifter seal
March 11, 2012, 10:30:32 AM »
Quote from: Mike on March 11, 2012, 10:22:06 AM
No. just hook the old one with a pick or a screw and pull it out, clean the seat area well and push the new one in.
RP#62
Gilbert, AZ
Re: shifter seal
March 11, 2012, 12:53:29 PM »
I don't know if this is mentioned anywhere, but anytime you're sliding a new seal over a splined shaft, its a good idea to wrap a piece of paper or something thin like that over the splines, then slide the seal on. That will keep the new seal from being cut if there are any burrs in the splines.
-RP
eRaGoN
Re: shifter seal
Reply #6 on:
March 11, 2012, 09:16:44 PM »
Thank you John.
BradValk48237
Oak Park, MI
Re: shifter seal
Reply #7 on:
March 12, 2012, 12:29:57 PM »
Did mine last year.... hardest part is getting the shifter back in the right/same position...
B
=> InZane XXV
