February 12, 2026, 02:08:59 AM *
Author Topic: changing shifter seal  (Read 1671 times)
Mike in AR
Redfield, Arkansas 72132
« on: March 12, 2012, 04:16:05 PM »
I am trying to change out my shifter seal. I have the foot peg removed, and the bolt in the shifter extension removed also. I thought the extension would just pull straight out off of the shifter, but it is as if the bolt is still in it, which it is not. Any thoughts on how to remove it so I can get to the shifter seal to remove and replace would be greatly appreciated. I am going by Daniel Meyers instruction. I don't think I missed any steps up to this point.   Smiley
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: March 12, 2012, 04:21:16 PM »
With the bolt completely removed, if it is stuck, then you might need to use a flat blade screwdriver to slightly pry apart the shifter a bit to slip off. Mine has never done this, so I'm just guessing.
« Reply #2 on: March 12, 2012, 05:40:18 PM »
It might be in shop talk but as I recall, you can drill a sheetrock screw into the seal next to the shaft. Then pull with some pliers. Tap the new one in with a socket of the right size.
« Reply #3 on: March 12, 2012, 05:53:45 PM »
  Had to do this when i changed mine out last year.  coolsmiley Then what sandy said and cleaning the area up BEFORE you install the new shifter seal and yer good to go. cooldude RIDE SAFE.
sonofscrooge
Elgin, IL
« Reply #4 on: January 27, 2015, 11:46:28 AM »
I may be blind but I cannot find any instructions regarding the changing of the shifter seal. Any help would be appreciated.
I just changed the timing belts and had no issues. Will this job be more difficult than that?
« Reply #5 on: January 27, 2015, 01:35:18 PM »
shifter seal way easier than belts.  once you get that shifter arm off clean the are real good first then just use a curved point ice pick to pull that thing out.  Lightly lube the new one with clean engine oil and press it in being careful to keep it square to the motor.
« Reply #6 on: January 27, 2015, 01:35:56 PM »
    After removal of shift lever follow reply #2. And also reply #3. It's so EASY I wuz able ta dun did it!  2funny RIDE SAFE.
sonofscrooge
Elgin, IL
« Reply #7 on: January 27, 2015, 06:19:56 PM »
Thanks folks! Any suggestion as to where I should order the seal?
Daniel Meyer
The State of confusion.
« Reply #8 on: January 27, 2015, 06:36:09 PM »
Instructions and pics here:
http://lifeisaroad.com/valkshiftseal.html
CUAgain,
Daniel Meyer
sonofscrooge
Elgin, IL
« Reply #9 on: January 27, 2015, 06:53:04 PM »
Thank You, Thank You, Thank You
« Reply #10 on: January 28, 2015, 09:14:51 AM »
The most common problem with changing out the shifter
seal is the inability to replace the parts back to the
original position thereby causing shifting problems.
« Reply #11 on: January 28, 2015, 06:26:44 PM »
R-D, are you referring to the alignment of the shifter onto the shift rod extension, so it is clocked properly?
Just mark the parts with a felt pen before removing.
« Last Edit: January 28, 2015, 06:32:03 PM by gordonv » Logged
sonofscrooge
Elgin, IL
« Reply #12 on: January 28, 2015, 07:02:34 PM »
Good stuff here. I feel much more comfortable trying to do this job.
Woton
Central North Carolina
« Reply #13 on: June 24, 2016, 11:02:11 AM »
It just happened to me! tickedoff
A mere 65K and not a week home from Inzane XVI - and ready to give the ol' girl her first bath and possibly a wax...
And then I see a somewhat oily spot on the mat under the front of the engine!
A closer look...and there's telltale dry oil all around the shifter/engine interface!
Feeling just like Daniel Meyer in his earlier post!  Ice tea didn't do it, though - BikerGirl had to bring me a beer!
To top it all off the replacement seal is $3.30!!!
Thank goodness she's worth both the money and the time! cooldude
"Ride Smart - Ride Safe"
