August 20, 2025, 08:26:35 PM *
Author Topic: Manifold O-rings  (Read 1762 times)
nerider2
Omaha, NE
« on: March 12, 2012, 06:01:00 PM »
It looks like I have some leakage on the manifold O-rings on the cylinder head.  Can you replace these O-rings without pulling off the Carbs?
Can I order these from allorings.com?  What material and size of O-rings?
Honda part number is O-RING (2.4X29) 16075-GHB-B70.
Ed
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
« Reply #1 on: March 12, 2012, 06:07:22 PM »
Yep, they come right off.. Its easy.. Remove the two retainers and loosen the clamps, they'll pull right out..
You can match the o-rings up at your friendly local hardware store, they are either #122 or #123, I forget which..
nerider2
Omaha, NE
« Reply #2 on: March 12, 2012, 06:43:26 PM »
Thanks Patrick.
Omaha, NE
VRCC #23874
JetDriver
Columbus, OH
« Reply #3 on: March 12, 2012, 08:51:34 PM »
Some guys have reported that regular auto-parts or hardware store o-rings deteriorate fairly rapidly.  Check these out from Redeye.  Good reports on these and dealing with him is great.
http://redeye.ecrater.com/p/2064055/intake-runner-o-ring-kit-viton
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: March 12, 2012, 09:03:19 PM »
For sure buy the Viton O-Rings....THe others from the hardware will go south of the border very fast.  Red eye is very good people to deal with.
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: March 13, 2012, 12:01:36 AM »
Carolina bike and trike sells them, cheap.
http://www.carolinabikeandtrike.com/ORings.htm
Also get the final drive O-rings for rear wheel maintenance. 5 sets for cheap...
Fred.
« Last Edit: March 13, 2012, 12:03:33 AM by PhredValk » Logged
VRCCDS0237
Brian
Monroe, NC
« Reply #6 on: March 14, 2012, 03:07:30 AM »
 :cooldude:thumbs up on Redeye andCarolina Bike and Trike. I ordered the rear o-rings on Sunday and they were in my mailbox on Tuesday.
« Reply #7 on: March 14, 2012, 12:54:29 PM »
Do the cheap ones from the hardware store go bad quickly ??  I didn't know that.. I replaced mine in '99 when I desmogged and smoothed the intakes.. I guess I won't mention it to them..  Roll Eyes
« Reply #8 on: March 14, 2012, 06:03:32 PM »
The Hardware O rings are usually Buna N material. Viton and silicone are rated for heat and petroleum distilates. My vitons are several years old and have never shown any leakage. They are a #123 in viton.
NITRO
Eau Claire, WI
« Reply #9 on: March 14, 2012, 06:55:10 PM »
Just be careful that you don't pull the tube off from under the tank when you pull the intake tube out!
When in doubt, ride.
paps350
Pittsburgh Pa
« Reply #10 on: March 15, 2012, 12:51:14 PM »
Just replaced intake O-Rings and I ordered from Redeye and I had them in 4 days. Ordered final drive O-Rings from Carolina and also came in 4 days.
redflash
Southern New Hampshire
« Reply #11 on: March 15, 2012, 01:18:53 PM »
just ordered redeye's rings, I can see some leakage around the ones in the right bank only, but might as well change all 6, she's got 80K on her.
toetruck21
Wahoo, NE
« Reply #12 on: March 15, 2012, 05:04:37 PM »
Nerider2, I ordered the set from Red Eye Technical Services, will be putting them in tonight if you want to ride out to Wahoo and help!  I should be able to handle this myself but if you need a reason to ride somewhere your more then welcome to come out!  Call four zero two four four three nine five seven five.
VRCC# 32877
1999 Valkyrie Interstate Red/Black
