August 20, 2025, 08:15:07 PM *
Author Topic: Progressive 440 question  (Read 960 times)
lucky_1_chris
Arlington, TX
« on: March 18, 2012, 11:37:40 AM »
I was adjusting my shocks today and noticed that the whole shock (spring, strut, and bottom cup) turned with the top while tightening the preload. This is normal for these...? I also noticed oil on the notches on the top... Is this the beginning of a leak, or is this possibly some sort of lube put on at the factory? They're only 6 mos. old, and until today they've always been on the lightest preload adjustment.
Gracias.
1999 Valkyrie Interstate
Bob E.
Canonsburg, PA
« Reply #1 on: March 20, 2012, 08:57:20 AM »
All the parts turning isn't a big deal.  I found that they are alot easier to adjust if you raise the bike on a lift to get the weight off the rear springs.
As to leaking...when mine leaked, I saw an oily residue that collected alot of dirt near the bottoms of the shocks.  I sent them back to Progressive and they rebuilt them and even put new chrome springs on.  Unfortunately, they are leaking again.  I should have sent them back over the winter for another rebuild, but never got to it.  Luckily, I saved my old OEM shocks to use if/when I do actually get around to sending them back.
lucky_1_chris
Arlington, TX
« Reply #2 on: March 20, 2012, 08:32:36 PM »
Luckily ive got no oil at the bottom of the shocks, just on the exposed notches. Ive haven't had them adjusted below the lowest setting til now so for all I know its been there since new.
