Firefighter
« on: March 19, 2012, 07:50:40 PM » |
I know this has been discussed a lot but I have a 2000 IS, have always wanted to install a cruise control. Have read a lot but want to make sure. Would like to use a unit that is electronic not vacuum, but also like to take advantage of IS electronic speedometer and not have to add parts to the front wheel. I see the audiovox ccs100 (vacuum), and the too expensive mcs4530. Are those my best two choices? What do you guys like best? Thanks
2000 Valkyrie Interstate, Black/Red 2006 Honda Sabre 1100 2013 Honda Spirit 750 2002 Honda Rebel 250 1978 Honda 750
al v
« Reply #1 on: March 19, 2012, 08:30:56 PM » |
I would like to go the true cruise control route someday as well. Perhaps a winter project. After recently moving my breakaway throttle control from another bike, I was surprised at how well the valk can hold a constant speed. I mostly use the throttle lock to give my hand a break for 5 minutes or so. I found my bike stays within plus or minus 1 or 2 mph even with strong wind and small hills. My other bike would require constant adjustment.
Mr.BubblesVRCCDS0008
« Reply #2 on: March 20, 2012, 04:17:47 AM » |
I've been running the vac audiovox unit for over 6yrs now with no problems other that a broken wire which I did myself. I've also installed four of these units for other valkers. There is an electronic newer version of this unit. The speed is control by input from the coil to hold rpms so no magnets on the wheel are needed. The interstate has plenty of room under the fairing for anything you decide to use. Good luck and it'll be one of the best add ons you'll ever put on your bike.
N0tac0p
« Reply #4 on: March 20, 2012, 05:39:57 AM » |
mr. bubbles, the link sends us to the clone of the vacuum operated cruise. do you have a link or item # for the electronic one you reference?
N0tac0p
« Reply #6 on: March 20, 2012, 08:03:06 AM » |
WOW looks like it. for $240, sweet.
Question, are there VALK instrucitons anywhere you know of?
olddog1946
« Reply #7 on: March 20, 2012, 08:31:37 AM » |
Use that part number 250-1223 and do a search, they can be found cheaper than $240..I do already have a controller so that might be why I found some cheaper... I can't find my notes right off so I can't give you any links.
« Last Edit: March 20, 2012, 08:57:19 AM by olddog1946 »
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
« Reply #8 on: March 20, 2012, 08:40:35 AM » |
I went the expensive Australian in 1997.
It has not failed in any way shape or form.
Still holds + or - 2-3 MPH, even in hilly country.
Would I do it again, ur damn right I would.
I don't mind installing things, but damn I hate to have to go in an repair it.
PharmBoy
« Reply #9 on: March 20, 2012, 09:59:05 AM » |
+1 for R.J. Installed mine in '08 and would not trade it for any other. No Problems, 100% satisfaction...Jim
A politician is a fellow who will lay down your life for his country. ~Texas Guinan 4th Infantry Tet Vet 99 Interstate 97 Bumble Bee 97 Red & White
N0tac0p
« Reply #10 on: March 20, 2012, 10:29:07 AM » |
yeh that expensive austalian in 97 was 300 probably now its 1100
