August 20, 2025, 08:14:02 PM
fuel sender unit
Topic: fuel sender unit (Read 899 times)
Alaskamike
gittin her done!
Wasilla, Alaska
fuel sender unit
March 20, 2012, 04:05:30 PM »
Is there a correct position for fuel sender unit install? To front of tank or to rear? Thanks.
"If you don't ride in the rain.... you don't ride"
tank_post142
south florida
Re: fuel sender unit
March 20, 2012, 05:35:40 PM »
the wire harness points
rearwards
putting the sending unit in the rt side of the tank. so it swings from top front down to bottom of tank
NOTE: the Gentlemen below are correct. i pulled two sending units out of my stash of parts. i modified my response in red to reflect my big dumbassedness !! sorry
Last Edit: March 20, 2012, 05:56:55 PM by tank_post142
I got a rock
VRCCDS0246
Madmike
Campbell River BC, Canada
March 20, 2012, 05:36:24 PM »
I know it is directional but can;t recall which way right now..... maybe archives will help.
BonS
Blue Springs, MO
March 20, 2012, 05:43:01 PM »
Quote from: tank_post142 on March 20, 2012, 05:35:40 PM
the wire harness points forward putting the sending unit in the rt side of the tank. so it swings from top front down to bottom of tank
And that orientation has the wires exit to the back of the tank.
March 20, 2012, 05:46:03 PM »
Tank, I think you have it backwards....or I'm reading you wrong. With the tank in front of you upside down(bottoms up) on a towel or blanket, as I recall the harness should feed/point toward the rear of the tank.
tank_post142
south florida
March 20, 2012, 05:57:53 PM »
http://www.dealercostparts.com/pages/OemParts?aribrand=HOM#/Honda/GL1500CF_A_%2801%29_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC410-1A200001/FUEL_TANK/GL1500CF-01-A/2Y14MBYXMBY4F1700AC
I got a rock
VRCCDS0246
Alaskamike
gittin her done!
Wasilla, Alaska
Reply #6 on:
March 20, 2012, 10:29:47 PM »
Thank you gentlemen That helps allot !
=> InZane XXV
