March 09, 2026, 12:01:24 PM *
Author Topic: Back Peddling?  (Read 2514 times)
Jeff K
« on: May 18, 2009, 08:20:36 AM »
When did the phrase "back Paddling" turn in to "back peddling"?  Undecided
They aren't even close.
« Reply #1 on: May 18, 2009, 12:01:34 PM »
Back peddling as in reverse the pedals on a bike so as to slow down or stop. A futile exercise cause most bikes will just free wheel.
Jeff K
« Reply #2 on: May 18, 2009, 12:18:07 PM »
If a person "back-paddles" they are going back on something they said, changing their mind. So when you are "back-peddling" you would be doing nothing? Undecided
gregc
Media Pa.
« Reply #3 on: May 18, 2009, 12:52:54 PM »
  If it is being used by one of our politicians, back peddling would be right, they shouldn't ride anything but tricycles, or they might hurt themselves. And you can back pedal on a tricycle.
Jeff K
« Reply #4 on: May 18, 2009, 12:56:36 PM »
Are you sure? I figure they are up shite creek, so they should be back paddling. 2funny
Big IV
Iron Station, NC 28080
« Reply #5 on: May 18, 2009, 02:18:31 PM »
they're trying to go backwards in each case, rather futile effort in both cases generally.
I'd say the idioms are very similar in purposeful usage.
As to when did it change? I would propose that it hasn't really.
Both seem to be Americanized sayings. I think the difference is more regional than time order.
But that is just my 2 cents worth.
"Ride Free Citizen!"
VRCCDS0176
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: May 18, 2009, 04:28:38 PM »
Down here, back paddling is known as crawfishing.   Cheesy
PAVALKER
Pittsburgh, Pa
« Reply #7 on: May 19, 2009, 03:50:25 AM »
Hmmmm, when I first read the subject I initially thought this would have been a political post about Nancy Pelosi or something.   cooldude
I believe people use the terms "Back Peddling", "Back Paddling" and "Back Stepping" as one in the same....., reversing their views or  moving away or back away from their original position.   Obviously, Back Driving or Back Flying doesn't sound good, so they were not used. Shocked   And as some have noted, it is most applicable and widely observed within the political arena.
« Last Edit: May 19, 2009, 04:57:54 AM by PAVALKER » Logged
John
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #8 on: May 19, 2009, 03:57:54 AM »
My interpertation was the "back paddler" was trying to go back, or back out of something they had said. Back out of a dangerous situation. Same as a canoe, backpaddling to avoid rocks, or a drop.
Blackduck KS
Atitude Is Everything
Wichita KS.
« Reply #9 on: May 19, 2009, 04:33:44 AM »
When I was little my DAD use to use this term very profondly,
 to describe someone who was not good for there word ,such as someone
who was going to sell something or made a promise to do something then
back peddled to get out of it or the other term that came after that was shizziester.
And yes they still exsist today .  Just talk to one of our goverment Rep  2funny
« Reply #10 on: May 19, 2009, 09:29:07 AM »
Although we quickly attach the term "back pedal" to bicycling, I don't think that's where it came from.  Pedaling backwards on a bicycle either accomplishes nothing or simply stops forward motion, depending upon the bike.
If the term is old enough, I suppose it could have referred to bicycling when the pedals were directly attached to the wheel.
The word pedal actually means of or like the foot.
I think the boxing term is more likely where back pedaling made its way into common usage.  A boxer who is back pedaling is usually trying to retreat from an undesirable position.  He is, in that situation, moving his feet in a backward direction, although possibly reminiscent of a motion made on a bicycle.
I've not heard anyone use the phrase back paddling other than in a canoeing application.  That may be simply a matter of my and someone else's geographical history.
I have paddled several backsides.  Cry  Would that be back paddling?    Roll Eyes
Ted_N
« Reply #11 on: May 21, 2009, 01:55:47 AM »
Actually, you can back-pedal on a fixed gear or track bike.  No free wheeling function there.  Fixies are in fashion these days.  Check out the sandwich shop delivery folks around a college campus.  Having said that,  I'm inclined to agree with Willow that the term came from boxing.
stormrider
Kinsey, AL
« Reply #12 on: May 21, 2009, 06:31:17 AM »
Having canoed for many years, back-paddling is often referred to as a back stroke. It is a very useful manuver in moving a canoe or kayak towards a more desirable direction, whether it be to avoid something, re-direct the boat into a better route, to surf a hydrolic, or to avoid going over the fall that has just appeared out of nowhere.  So, in this case, back-paddling is very useful and can be lifesaving.
