February 04, 2026, 07:10:13 PM *
Author Topic: short circuit  (Read 1507 times)
scubaman458
« on: March 21, 2012, 09:14:31 PM »
well, here it is. I have a short circuit on the tail / meter 10 amp circuit of my 98 standard. does anyone have any idea of the first place to look without my having to follow the entire circuit looking for it? I started it while trying to hook up my light bar without a relay, a fatal error.....
RonW
Newport Beach
« Reply #1 on: March 21, 2012, 09:51:37 PM »
disconnect the tail light bulb. If the fuse blows still, disconnect the p-connectors within the meter circuit .... to isolate the culprit by process of elimination. There's a 9-P (white) to the tach. A 2-P (white) to the speedometer. A 6-P (green) to the idiot lights. You also can't rule out the fuse socket itself isn't defective and arcing. The simpliest would be tail light connector under the fender or one of the p-connectors are dangling. The wires at the p-connectors don't have a stress relief and some times there's a short there because owners yank and twist the female and male halves apart to disconnect them. If it's a pinched wire, best wishes.
2000 Valkyrie Tourer
Mr.BubblesVRCCDS0008
« Reply #2 on: March 22, 2012, 06:54:57 AM »
If memory services me right there several things on that circuit besides the tail light. Seems the tach and horn are also on it.
« Reply #3 on: March 22, 2012, 07:06:32 AM »
I'm a long way away from my books so I can't be much help.. But, what are things doing, or not doing.. By short, we're assuming you're blowing fuses.. If things are not working then we need to look for opens..
RonW
Newport Beach
« Reply #4 on: March 22, 2012, 08:01:53 AM »
the horn is instead on the Stop fuse circuit along with the turnsignals. The Stop and the Tail Light filaments are in the same rear bulb but the circuits are designed separately to avoid a situation that you don't have any rear lights as would be the case if the Tail and Stop were on the same fuse and one caused an overload disabling both un-isolated from one another. The excess capacity on the Tail Light fuse is used by the meter electricity, instead of the meter having a separate fuse of its own, thusly, "Tail/Meter" fuse. I'm unclear on the idiot lights .... if only the neutral indicator is wired to the Tail/Meter fuse circuit and not the adjacent high-light indicator and the turn signal indicator since they're not interconnected. Whereas, the oil, sidestand, and water temperature lights in the tach housing are wired to their corresponding circuits, er, not to the Meter/Tail circuit. Despite those little lights being in the tachometer, they're not wired to the Meter fuse. Anyways, the Tail/Meter circuit doesn't have anything to do with the auxiliary lights unless it was mistakenly tapped into or incurred collateral damage from whatever. The auxiliary lights should have blown the headlight fuse, so something's odd. (as frequently the case)
scubaman458
« Reply #5 on: April 16, 2012, 05:45:19 PM »
GUESS WHAT! turns out that the turn signal switch was fried like a good steak! my local repair shop found it after I gave up hunting for the short.. never thought it would be on that side of the bike...
