November 24, 2025, 01:44:54 AM *
Author Topic: Engine miss help  (Read 1538 times)
22Dasher
Shelbyville, TN
« on: March 21, 2012, 09:59:12 PM »
I have a friend who has I Yamaha and has a bit of miss in it from sitting over the winter, we poured seafoam into it and that helped some but it still has just a slight miss there. I remember reading a couple years ago of another cleaner you guys used to pour in the tank thats a bit better and stronger than seafoam. I tried searching but couldn't find it so I'm here to ask what was the other cleaner you guys ran thru the tank besides seafoam?
James
« Reply #1 on: March 21, 2012, 10:11:52 PM »
Carbed Yamahas are notorious for completely gummed up carbs from sitting with ethanol garbage in the gas.  My wife's V*1100 had to have a complete carb tear down, twice.  No amount of solvent did anything, it would not start or run.  YMMV
olddog1946
Moses Lake, Wa
« Reply #2 on: March 21, 2012, 10:37:33 PM »
Try some Star Tron, sold at Wally World..can find it in the fishing section..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
BonS
Blue Springs, MO
« Reply #3 on: March 22, 2012, 06:22:48 AM »
Techron fuel system cleaner, by Chevron, is commonly recommended.
« Reply #4 on: March 22, 2012, 06:46:03 AM »
Star Tron is a fuel (ethonal) stabilizer, but not a carb/fuel system cleaner.  Once the carbs are gummed up, I doubt it will help.  I could be wrong.
22Dasher
Shelbyville, TN
« Reply #5 on: March 22, 2012, 08:56:25 AM »
Thanks guys I will pick up some Techron for his bike hopefully this will fix it.
James
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #6 on: March 22, 2012, 09:10:15 AM »
Check you local O'Rilley's auto part store- Techron is on sale, Buy one, get one free, $7.99 for two bottles. cooldude
Dave
« Last Edit: March 22, 2012, 08:44:24 PM by DenverDave » Logged
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
olddog1946
Moses Lake, Wa
« Reply #7 on: March 22, 2012, 08:41:37 PM »
Directly from the attached label on a bottle of Star Tron
>Cleans valves and injectors
>removes carbon and varnish
www.starbrite.com
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #8 on: March 22, 2012, 10:16:35 PM »
www.starbrite.com
Then I am corrected.  The very small amount called for per gallon/tank would not seem capable of cleaning the fuel system.  I thought it was an enzyme only to treat/counteract ethanol and moisture in the tank.
