November 24, 2025, 01:45:40 AM *
Author Topic: Honda moly paste?????  (Read 1993 times)
Brian
Monroe, NC
« on: March 22, 2012, 03:12:17 AM »
okay,took the rear wheel off after 3,000 miles to inspect  all the drive line splines. You guys have sent many comments on the poor adhession qualties of the Honda paste. From what I see here you are correct. The first pic is the wheel right off the bike. I had the camera set wrong so you may not see the shiny teeth that have nothing on them. I have since taken everyone's advice and used the GD-525 on all the splines and replaced the 3 O-rings.
« Reply #1 on: March 22, 2012, 03:55:38 AM »
The last time I had the wheel off, I inserted the flange
into the final drive a few times, paying attention to
getting the o-ring all the way seated. The two
parts seemed really well sealed together. It made me think
that maybe all that "blowby" stuff you always see when
you're changing tires might just be moly that was beyond
the o-ring during assembly.
Anyhow, I tried to be real careful not to get any moly outside
the closed part of the system when I put my wheel on last
time... I'll get a chance to look at it again in a few thousand miles...
Your splines look good!
Westsider
Fort Worth TX.
« Reply #2 on: March 22, 2012, 06:34:11 AM »
Yep, probly just put a little to much on, witch is a lot better than not enough. cooldude
Like the shop talk and Daniel M. says, just do it correctly,  every 10k,
Splines do look good and can stay that way with alittle TLC.
olddog1946
Moses Lake, Wa
« Reply #3 on: March 22, 2012, 06:37:15 AM »
Those flange splines look pristine..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #4 on: March 22, 2012, 06:55:16 AM »
I believe the biggest cause of "blow by" is putting grease on the male part(flange)  as the flange is pressed into the final drive the majority of that greas is simply pushed off and thats what you see slung around.
I put the majority of the grease inside the final drive and most of it at the opening, I dont try too hard to get it deep inside just evenly all the way around.  That way as the flange goes in it pushes the grease inside the hub instead out outside.
Thats my story and Im sticking to it.
+1 on the Honda grease is no good, doesnt adhere and is not water resistant
« Last Edit: March 22, 2012, 12:47:09 PM by Chrisj CMA » Logged
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #5 on: March 22, 2012, 10:58:39 AM »
I bought some stuff at rileys auto parts. I couldn't get it off my hands with go jo and a water hose. It must be ok
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #6 on: March 22, 2012, 04:04:42 PM »
I tried to get molly paste at honda. It wasn't in stock. They had to look it up, and said they could order it. I used Bel-ray. Hope I didn't use to much. Is there really any way the spline could not be in all the way? Seems to me 80 lbs on the axel bolt would pull it together.
John U.
Southern Delaware
« Reply #7 on: March 22, 2012, 04:55:24 PM »
No worries about it being in all the way, you're right once it's torqued it's together. The O-rings can get worn and let grease out and water in. Carolinabikeandtrike.com  has packs of 5 sets for a reasonable price.
Also, be sure to torque the axle bolt and then the 4 bolts that hold the pumkin to the swing arm. They ahould already have been loose so you could check the grease on both ends of the drive shaft.
xman
« Reply #8 on: March 22, 2012, 06:00:37 PM »
Correct John,  I had the 4 bolts loose, maybe 1 turn. I didn't want to leave it to loose as I wanted to be able to close the gap from the pumpkin to swing arm. Couldn't get the torque wrench on these bolts, but years of wrenchin I can tell.    I greased heavy both sides of the flange, female side of spline, axle. even a little on the pins. All new O rings dust seal. Hope I'm not cleaning grease off of everything all summer.
