November 24, 2025, 01:45:04 AM *
Author Topic: Buddies Valk revs quicker. Ques?  (Read 2004 times)
dr.danh
« on: March 22, 2012, 07:12:52 AM »
Rode with a friend other day. He has a 98 Valk Std. with 15k miles.  I have 01 I/S. with 85k miles. His bike revs up quicker. I have the 6 deg. trigger wheel, glasspack mod. and more miles. Any idea on what the dif. might be,why his revs up quicker. Do I need to go bk. with the stock TW or sync. the carbs. ? Thought mine was the powerhouse til sit on his.
TJ
Lake Placid , Fl.
« Reply #1 on: March 22, 2012, 07:57:01 AM »
about 100 lbs....
« Reply #2 on: March 22, 2012, 08:42:58 AM »
Its been awhile since trigger wheels were hot for discussion but I think I remember its not good for the IS to have a 6° one.  Since the engine is already advanced over the standard and tourer.  I believe the 4° is what the IS should use.  With the 6° on an IS I sure hope you are using premium fuel.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #3 on: March 22, 2012, 09:03:20 AM »
#1 on what chrisj said....the gold wing 1500, and the valkyrie interstate both should use the 4-degree trigger wheel.  the 6-degree wheel is too much advance with the computer that is on them.
« Reply #4 on: March 22, 2012, 09:19:02 AM »
all use the same OEM TW.
I/S ICM has a faster steeper advance curve to 3k than non I/S, after 3k rpms, the curves are the same for ALL ICMs all models. This is the ONLY difference btwn the I/S and Standard ICMs.
see curves here,  http://timskelton.com/valkyrie/tech/trigger_wheel_plus_dyna3000.htm
which also shows area that the ECM mod affects
6 and 4 TW reduces HP at higher RPMs, the ICMs also have a HP reducing spike in the curve at about 5800rpm, "the engine hates advanced timing settings much above 25-27 degrees at rpms above 5000", "According to Hondatek's data the 1520 will actually lose 1 HP per degree over 26 total." plus  a rev limiter at 6200rpm
dr.danh
« Reply #5 on: March 22, 2012, 09:32:34 AM »
ok. so you are saying actually with the trigger wheel dosen't affect the low end rpms. AND that the Std. is suppose to rev. quicker. Sorry if ignorant on this. Would it be to my best interest to go back with the oem. or maybe a 4deg. I do run reg. octane and don't get any clatter. But I have noticed that on a incline don't seem to have the pulling power I would like. Kinda disappointed in the beast right now.  Thanx
« Reply #6 on: March 22, 2012, 10:17:56 AM »
I'm not a big fan of the aftermarket triggers.. I've tried 'em and removed 'em..
But, between the extra weight, the trigger and maybe the exhaust is all of what is causing your bike to be a bit slower.. A vacuum leak or dirty or different air filter could contribute.. Plus, not all engines are created equal, some just run better than others.. Thats one of life's little wonderments..  After awhile you'll just relax and sit back and enjoy the ride..
art
Grants Pass,Or
Grants Pass,Or
« Reply #7 on: March 22, 2012, 10:57:23 AM »
I have a six degree wheel on my 02 standard an it runs like a raped ape no pinging an I use regular gas.I have natural low blood pressure and if I get on the gas from a stop full trottle I get dizzy an Have to back off.I would like to take the valk to the drag strip but don't think I could handle it.
« Reply #8 on: March 22, 2012, 11:21:40 AM »
Good to heed what CA says!
You wont necessarily hear detonation before damage can occur.
Exhaust modifications will reduce the performance of your Valkyrie.
Weight consumes horsepower.
The other bike may just be faster.
custom1
01 Interstate
SW Pa
« Reply #9 on: March 22, 2012, 11:23:28 AM »
Umm. I think this should be your sig line.        Also maybe don't do that!
John
The Anvil
Derry, NH
« Reply #10 on: March 22, 2012, 12:25:44 PM »
Does he have IS carb springs??? That will make it feel more lively.
The Anvil
Derry, NH
« Reply #11 on: March 22, 2012, 12:27:38 PM »
This is a falsehood.
F6Cruzer
Robbinsville, NC
« Reply #12 on: March 22, 2012, 12:44:13 PM »
I had a 6 degree trigger wheel on my 03. When I swapped the ICM to the Interstate ICM, I had to back down to a 4 degree trigger wheel.  Added the Interstate carb springs and I have tremendous throttle response.
I live near the Tail of the Dragon!
Tailgate Tommy
Fort Collins, Colorado
« Reply #13 on: March 22, 2012, 12:52:31 PM »
Must have been a black one...
Brian
Monroe, NC
« Reply #14 on: March 22, 2012, 06:36:53 PM »
So would interstate carb springs make my 97 take off like a raped ape? Do they really make that big of a difference?
« Reply #15 on: March 22, 2012, 07:28:36 PM »
the lighter springs act like an accelerator pump, allowing the slide to lift the needle out the needle well faster allowing more fuel into the airstream.
Cliff
Manchester, NH
« Reply #16 on: March 23, 2012, 06:27:17 AM »
Need to more clearly define "revs up quicker".
VRCC # 29680
dr.danh
« Reply #17 on: March 23, 2012, 07:07:17 AM »
ok. By just sitting on the bike. The throttle had a quicker response. One thought. I have the k&n filter with the foam pre-filter on top. That could be restricting the air intake. (Cleaned it awhile bk. so is not dirty.) What ya think?  Also, Do the trigger wheels affect rev. up as mentioned?
Brian
Monroe, NC
« Reply #18 on: March 23, 2012, 05:25:38 PM »
So would these then hurt the gas mileage for a quicker throttle reponse?
PINSTRIPERART
I ride a 2000 valk tourer
san antonio
« Reply #19 on: March 23, 2012, 06:08:21 PM »
Remember the 98 had more HP than the later models. It was not de tuned like the following years
« Reply #20 on: March 23, 2012, 06:18:41 PM »
So, your talking about engine revving while sitting still ??!!  I'm not touching that.. Its been well covered..
The detune was supposedly in '98..  The 96 and 97's supposedly had different needles [carburetor numbers are different and needles are the only thing I've found different],, but, there were also rumors years ago about the camshafts being different but no part numbers were given [that I could find] that differed from 98 and beyond..
dubsider
Flat6 baby #33034
Dublin GA
« Reply #21 on: March 23, 2012, 06:31:22 PM »
I have the same set up.
'01 Standard. (43,000 miles). 4* trigger wheel. Interstate ICM. Interstate carb springs. I do run Premium NON-ethanol gas.  very happy.
Dirty Dave
Montreal, Canada
« Reply #22 on: March 23, 2012, 07:35:12 PM »
Always liked the throttle response of the I/S over the Std. Did the I/S mods and the ECT mod and am very happy. My 97 (with 2000 carbs) runs great. The trigger wheel mod was trashed after trying the ECT. One day I'll rebuild the 97 carbs and re-install. Just too lazy now to dig into a pefectly running Valk with great gas mileage, if I lay of the throttle.
