November 24, 2025, 12:34:29 AM *
Author Topic: Is this what bad shock bushings look like?  (Read 2211 times)
al v
Clinton Township, MI
« on: March 22, 2012, 08:05:37 PM »
Was researching a slow front end bounce at 35 mph on the board and found tires being out of round and rear shock bushings as possible causes. I haven't checked the tire roundness yet, but here is what I found for my rear shock bushings.
I'm guessing the rubber bushings should be a bit more centered...
« Reply #1 on: March 22, 2012, 08:24:17 PM »
Yes. But I thought it would be thinner on the top?
olddog1946
Moses Lake, Wa
« Reply #2 on: March 22, 2012, 08:33:15 PM »
Yep, they are worn. Should be centered.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Canuck
Palmetto Bay FL
« Reply #3 on: March 23, 2012, 02:20:48 AM »
Mine looked like yours and this is what you'll find when you pull them.
Valkyrie ~ "chooser of the slain"
Chattanooga Mark
« Reply #4 on: March 23, 2012, 07:07:43 AM »
My top Interstate bushings looked just like Canuck's as pictured. I just installed the poly bushings from Gary. My Interstate also has a slight head shake at 40mph to 45mph as I'm slowing down. I hope the new bushings help address that. I also checked the pressure in my front and rear Dunlap E3 tires. 47 Rear and 44 front.
All the best,
Mark
www.bikersforchrist.org
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #5 on: March 23, 2012, 07:30:32 AM »
I use the head shake as a reminder it is time to replace the front tire due to low tread...or worst case the head bearings need replaced or tightened...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
al v
« Reply #6 on: March 29, 2012, 08:39:13 PM »
Replaced bushings with xf6 bushings. It's cold today so I only went for a short ride, but the bike rides much better and I was not able to reproduce the 35 mph bouncing. The suspension also feels a lot tighter when on the front brakes. Ride quality improved at all speeds. The bad bushings were pretty much still intact but they were compressed and egg shaped.
Bone
« Reply #7 on: March 30, 2012, 02:55:06 AM »
Bad shock bushings is the first thing I learned from the VRCC Tech site. My 98 Tourer had 22K miles when I bought her. Started reading the short life the bushings have so I went out to the cold garage. Wow my shocks looked like yours or worse. Sent my order to Gary the same day. Never would I have noticed them, shock bushings shot not on a motorcycle.
Thanks VRCC
GotValk
Champlin, MN
« Reply #8 on: March 30, 2012, 06:18:31 PM »
Towards the end of last year I also had the under 35mph wobble, I changed the shock bushing hoping it would help, the bike had 50,000 miles and the bushing were in pretty good shape, I change them anyway, They did not help at all still wobbled.
I finished the season out with the wobble, This spring while doing some maintenance I realized my tires had over 14,000 miles on them, So long story short New tires = No wobble.
The Rear was really cupped and the wear bars were starting to show, front looked good but changed it also.
Bottom line is she rides like new again. Smiley
« Reply #9 on: March 30, 2012, 06:29:48 PM »
Yup!
My rides:
redflash
Southern New Hampshire
« Reply #10 on: March 31, 2012, 06:38:26 AM »
Gary of XF6, either one, I need new, just rolled 80,000 and NEED them! Can someone point me please? i'll order today!! Just got new Redeye intake o-rings to install as well. Gotta keep the Fat Lady in good shape for another 80K!
wild6
(Old enough to know better)
Vernon, NJ
« Reply #11 on: March 31, 2012, 11:45:36 AM »
XF6: http://www.xf6-custom.com/partpages/bushings.html
Gary: http://rattlebars.com/cart/bushings.html
redflash
« Reply #12 on: March 31, 2012, 03:09:13 PM »
Thank you, thank you!
