March 30, 2026, 06:18:47 AM
Goldwing Gl1500 Ring & Pinion
Topic: Goldwing Gl1500 Ring & Pinion (Read 1119 times)
indybobm
Franklin, Indiana VRCC # 5258
March 24, 2012, 01:20:16 PM »
What is the difference between a Goldwing Gl1500 Ring & Pinion and a Valkyrie Ring & Pinion? Gear Ratio?
So many roads, so little time
VRCC # 5258
Momz
ABATE, AMA, & MRF rep.
Re: Goldwing Gl1500 Ring & Pinion
March 24, 2012, 02:15:42 PM »
The ring and pinion are the same, however the housing (casting) is different due to the shock mount.
ALWAYS QUESTION AUTHORITY!
alph
Eau Claire, WI.
March 24, 2012, 02:58:23 PM »
can it be modified to fit? is it only the outer housing that's different? are the internals the same so that a person can gut out one and swap parts? i thought the gears on one were streight and slotted on the other. (goldwing being diaginal for a quieter ride)
Ride Safe, Ride Often!!
Michvalk
Remus, Mi
March 24, 2012, 04:48:56 PM »
I think the transmission gears are the only thing cut different. The gears in the rear end are spiral cut on both model bikes. I think someone here has already used a Goldwing rear to rebuild a Valk housing. Have to do a search in the archives and see
