November 24, 2025, 12:30:42 AM *
Author Topic: cooling question  (Read 1050 times)
N0tac0p
« on: March 28, 2012, 06:25:15 AM »
last year i tried to somewhat "flush" my radiator.  you know drain and then run a garden hose thru it, start the bike to have the impellor move stuff around a bit.....
then i refilled - distilled water and abot half a bottle of water wetter, which many folks said helped their valk run cooler.
Mine still seems to have the fan kick in, hwen i am rining in 45-50 degree weather and stop for a light,  doesn't seem righ to me.
any thoughts on how to once again flush / prep / mix coolant and whatever to help the lady
« Reply #1 on: March 28, 2012, 07:04:38 AM »
Ambient temperature has little bearing on the heating/cooling of a Valkyrie.
It is not unusual to have the radiator fan operate when sitting at idle for a period of time.
I feel you are worrying unnecessarily.
N0tac0p
« Reply #2 on: March 28, 2012, 10:51:00 AM »
OK, thx.  was just thinking it wouldn't run as quickly as the ater wetter supposedlly helps transfer heat better and keeps it cooler.  perhaps  its not a 1+1=2 thing
BlueValk
Albuquerque, NM
« Reply #3 on: March 28, 2012, 01:07:02 PM »
Hopefully, you will get more opinions ....
I'm in NM where it keeps pretty warm.  My fan seldom comes on.  Mostly if I am in the garage tuning it.
After 12 years, I am sure that it has never come on in 40-50 degree weather.  How long are your stop lights?  Smiley
I would suggest that it is running too lean at idle.  Maybe partially clogged slow jets or idle screw passages.
BlueValk
