November 24, 2025, 12:30:37 AM
Strange findings?
Topic: Strange findings? (Read 1353 times)
Mr.BubblesVRCCDS0008
Strange findings?
March 29, 2012, 02:52:37 PM »
I was helping a fellow valker to remove his rear tire. He's going to the darkside so I said lets pull the final drive and check your pinion cup and shaft end. As I pulled the final drive a small spring looking thing fell out of the swingarm tube. You could tell it had been in there for awhile. The bike only has 34,000 miles on it and I think this was the first time the drive had been pulled. There is no spring showing on any parts break down I have seen. The seal in the pinion was good and in place and the seal behind the cup was also good. Spring is about the size of the springs that are behind the rubber seals. Anyway I think it has been in there since new but I don't think it belongs there. The cup on the pinion was dry and the shaft and cup need to be replaced so we're waiting on parts now. Also gonna pull the u-joint and check it before going back together. Any ideas on this spring.
Bone
Re: Strange findings?
March 29, 2012, 03:18:04 PM »
Did it look like # 3
March 29, 2012, 05:10:25 PM »
No it was a small wire and small wound spring.
tank_post142
south florida
March 29, 2012, 05:17:55 PM »
if it is about 1/8 in dia. and a few inches long it is probably from around the seal. if i remember there is one on the frt and the back of the seal.
I got a rock
VRCCDS0246
March 29, 2012, 05:30:10 PM »
I'd pull the seal just to make sure. Don't forget to replace all three Orings, etc. Let's us know if you identify the source of the spring, please.
My rides:
Madmike
Campbell River BC, Canada
March 29, 2012, 08:18:06 PM »
seal..
JC
The Beast
Franklin, TN
Reply #6 on:
March 30, 2012, 05:37:26 AM »
Quote from: Madmike on March 29, 2012, 08:18:06 PM
seal..
+1
it came out of the seal
RonW
Newport Beach
Reply #7 on:
March 30, 2012, 06:22:25 AM »
the seal thing looks something like
this
(Bigwolf) or
this
(hubcapsc).
2000 Valkyrie Tourer
Reply #8 on:
March 30, 2012, 08:12:20 AM »
OK spring is from the seal. Yes we're replacing the shaft, pinion cup, and the seal. Thanks for all the help.
=> InZane XXV
