February 04, 2026, 03:42:13 PM *
Author Topic: Brake/Clutch fluid - how much is required?  (Read 1391 times)
gordorad
Washington, MO
« on: March 29, 2012, 05:29:17 PM »
I'm going to replace the brake and clutch fluid.  Does anyone know how much all three lines hold??
Is a 12oz bottle enough??
Thanks.
Support the Arts!!    www.gordonradfordphotography.com
« Reply #1 on: March 29, 2012, 06:17:31 PM »
I'd buy the larger 32oz bottle of DOT4 from a place like Oreilly's . That way you'll have plenty if some of the reservoir systems are "gunky" and will need a couple or more flushings. 12oz may not cover your needs even if they are relatively clean. FWIW  Smiley
My rides:
« Reply #2 on: March 29, 2012, 06:44:13 PM »
Someone recently posted that they used less than a regular bottle to replace all their fluids. Will it be enought? It should be, unless already stated, your lines are really dirty. But then you could always go out and buy another bottle.
GotValk
Champlin, MN
« Reply #3 on: March 29, 2012, 06:53:26 PM »
When I did mine a couple weeks ago I was able to get by with 1 small bottle, But I used a Vacuum type bleeder plus sucked out all of the dirty fluid in the reservoir before flushing. I did just had enough , I did buy two small bottles and would do it again just in case, I wouldn't want to stop in the middle to go and buy more. It's just not that expensive.
Gary
gordorad
Washington, MO
« Reply #4 on: March 29, 2012, 07:15:27 PM »
Thanks...yes, it is one of the cheaper fluids.....I have almost a full 12 oz, so I'll pick up another.....and the big one as well!!
Thanks!!
gordo
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #5 on: March 29, 2012, 07:15:40 PM »
I just did both brakes and the clutch. I needed a little more than 1 of the standard size cans. I had 2 cans so it wasn't a problem.
« Reply #6 on: March 30, 2012, 05:55:33 PM »
Don't use any fluid that may been sitting around for awhile. Use only fresh fluid as this stuff is very hygroscopic, pulls water out of the atmosphere and goes bad.  tickedoff
My rides:
gordorad
Washington, MO
« Reply #7 on: March 30, 2012, 07:48:10 PM »
Replaced all three today.  Used about 15 ounces........FYI....
