January 28, 2026, 04:56:47 PM
2 valks run completely different
Topic: 2 valks run completely different (Read 2492 times)
clsimmonsjr
May 19, 2009, 01:53:17 PM »
here is the question, not really a problem, I have a 99 IS and a 98 tourer, the 99 runs smooth as silk with stock pipes and the other 99 I had with 6 into 6 did also, the 98 has six into six and backfires and pops a lot, runs good, just a lot of cracking and popping. I thought the carbs needed adjusted, but that didnt change anything, do you think anything is wrong, or is that just its nature?
Steve K (IA)
Cedar Rapids, Iowa
Re: 2 valks run completely different
May 19, 2009, 02:03:39 PM »
Sounds like it is sucking air where it's not supposed to. First place I would look....is the header nuts tight?
States I Have Ridden In
mikehallbackhoe
May 19, 2009, 05:26:22 PM »
the cobra pipes will make the valk pop , not enough back pressure, and running too lean
gregc
Media Pa.
May 19, 2009, 06:29:00 PM »
I have to question that Cobras make the Valkyrie pop. My Cobras have been on since it had 700 miles , and I have never heard it pop. Sounds to me like it is getting extra air into the mix from somewhere, start checking for a vac leak.
fldragon6
May 20, 2009, 05:08:52 AM »
Make sure that the upper and lower clamps above the carbs are tight. They have a tendancy to loosen up over time.
