January 28, 2026, 04:56:45 PM *
Author Topic: Rebuilding rear end  (Read 2276 times)
FryeVRCCDS0067
Brazil, IN
« on: May 19, 2009, 07:37:25 PM »
Does anyone have the PN's for the needed parts to rebuild the spline set in a valk rearend?
Thanks in advance.
Kingbee
VRCC# 576
Northern Illinois
« Reply #1 on: May 19, 2009, 07:57:56 PM »
You'd probably be time and $$ ahead (especially since you won't know what shims you need until you get in there) to buy a good used unit from a recycler like pinwall.
They have at least 5 units right now, check the PICs carefully
http://stores.shop.ebay.com/PinWall-Cycle-Parts-Inc__W0QQ_armrsZ1QQ_fsubZ5665389
1999 Interstate
2000 Interstate
2004 Rune
Madmike
Campbell River BC, Canada
« Reply #2 on: May 19, 2009, 08:54:32 PM »
http://www.hdlparts.com/fiche_section_detail.asp
this is for a 97, you likely want to specify your year etc.
FryeVRCCDS0067
Brazil, IN
« Reply #3 on: May 20, 2009, 02:18:50 AM »
I bought one last year. I thought it looked good in the pics but it still had more wear than I wanted when I got it. I am currently using it but I’d like to rebuild the one I took off with new parts. Then re-install it the next time I change rear tires.
Kingbee
VRCC# 576
Northern Illinois
« Reply #4 on: May 20, 2009, 05:44:19 AM »
When I took my toasted final drive to my dealer, they said I'd be better off finding a take-off unit, which I did.
You're going to spend $400 for parts, as you'll also need a new driven flange to match.
If the splines are 80% or so good, and you keep them properly lubed, they can still last forever.
I would buy this one in a heartbeat, if I needed one
http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-GL1500-1500-FINAL-DRIVE_W0QQcmdZViewItemQQ_trkparmsZQ7c301Q3a0Q7c293Q3a20Q7c294Q3a30QQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem518904dc4fQQitemZ350191148111QQptZMotorcyclesQ5fPartsQ5fAccessories
1999 Interstate
2000 Interstate
2004 Rune
