February 04, 2026, 03:41:46 PM *
Author Topic: front darkside tire size  (Read 1912 times)
hopper4674
altoona pa.
« on: April 02, 2012, 07:12:30 AM »
can any one tell me if a Conti Motion Sport Touring size 150-70-17 would be ok on the front of the valk
Alien
Ride Safe, Be Kind
Earth
« Reply #1 on: April 02, 2012, 07:18:26 AM »
I don't think that going Darkside in the front is a good idea safety wise.
« Reply #2 on: April 02, 2012, 07:25:23 AM »
Darkside refers to an automobile tire being employed on the rear of a motorcycle.
The key work being automobile.
You cannot easily put an automobile tire on the front and it would not be recommended, regardless.
Installing a rear designated motorcycle tire on the front of a motorcycle is not uncommon.
The only requirement when installing a rear designated motorcycle tire on the front of a motorcycle is that it fits the rim properly and the front generally.
You have merely misconstrued the word "Darkside"
« Last Edit: April 02, 2012, 08:05:36 AM by Ricky-D » Logged
wild6
(Old enough to know better)
Vernon, NJ
« Reply #3 on: April 02, 2012, 07:45:54 AM »
It would fit the rim and would spin slightly faster than stock. (speedo would read higher)
Looks like an ok choice.
Let us know how it performs if you decide to use it.
BTW: Remember that most here mount them backwards.
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: April 02, 2012, 07:49:45 AM »
Come on now!!!  Angry
Just because you have not done it before doesn't mean it can't be done.  cooldude
ALWAYS QUESTION AUTHORITY!
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #5 on: April 02, 2012, 07:50:33 AM »
"Darkside front" or "double darkside," means using a motorcycle rear tire (generally mounted in reverse rotation) on the front of the motorcycle.  By starting with 11/32" tread instead of the normal 6/32" as typical on "front" tires, you get much more mileage out of it.
As for your question:  The 150/70/17 is about 1 3/8" shorter than the original tire, causing a BIG speedometer error.  I'd suggest a 130/90/17 to maintain the height of the original tire.
I personally have a 150/70 on my Valk and register a 10 mph error as compared to the GPS.  The error was only 3 mph before I went to this size tire.
BTW, My Kenda tire with 13,000 miles looks like it has the same amount of rubber on it as my friend's "normal" front Avon tire he installed last week.
« Last Edit: April 02, 2012, 08:51:55 AM by Fudd » Logged
Save a horse, ride a Valkyrie
wild6
Vernon, NJ
« Reply #6 on: April 02, 2012, 07:58:00 AM »
I have a Conti Go Rear 130/90VB-17 waiting in-the-wings.
Have to wait for my Avon Cobra to wear-out later this year.
« Reply #7 on: April 02, 2012, 08:04:07 AM »
+1 on the Contigo, after 3k miles great tire, present amount of wear indicates it will go 20-25k miles.
running Quadboss in it
see pics on my bike
http://www.valkyrieforum.com/bbs/index.php/topic,12541.40.html
