November 24, 2025, 01:45:44 AM *
Author Topic: Steering stabilizer/ damper  (Read 1498 times)
artyc264
Randolph, Massachusetts
« on: April 03, 2012, 02:21:02 PM »
Just finished installing a sidecar onto my 03 Valkyrie Standard. I've got bad low speed wobble. I think I need a steering stabilizer. Can anyone help out with where I can purchase one? If you have one, photos would be awesome. I'm not sure where it would mount onto the bike. I'm guessing a universal clamp around the right side fork, but not sure where the other end would mount. Thanks,Arty
« Last Edit: April 03, 2012, 03:05:38 PM by artyc264 » Logged
BarendR
« Reply #1 on: April 03, 2012, 07:35:47 PM »
Though I don't have my sidecar on the Valk (yet), I had a similar problem with my Venture.  Try a heavier fork brace and/or see about adjusting your front tire pressure.  It may also be that you need to learn to accelerate through it.  When I first started with a hack I was very cautious, which made me linger too long in the wrong speed range-  I'm guessing 10-15mph?
Can we assume the hack is set up correctly?
« Reply #2 on: April 03, 2012, 10:12:04 PM »
There isn't a fork brace made for the Valkyrie.
Steering wobble, go back through your setting and measurements.
Something is off and it don't take too much.
MP
North Dakota
« Reply #3 on: April 04, 2012, 04:55:28 AM »
+1
Do you have a rake kit on?  Darrell made one for my 01 IS when I added the sidecar. What do you mean by wobble?  Is it moving you all over the road, or a front end quick shake?
At real slow speeds, if I hit a bump, my front wheel will shake back and forth some rapidly, but the bike does not change directions. It stops in a second or so, without really affecting anything.
MP
"Ridin' with Cycho"
« Reply #4 on: April 04, 2012, 05:19:22 AM »
u should peruse some hack sites. they will have the answers for u.
BarendR
« Reply #5 on: April 04, 2012, 06:10:08 AM »
Yeah!, I'm still new to the Valk ...... what can I say?!
DFragn
« Reply #6 on: April 04, 2012, 12:05:56 PM »
The Valk is such a robust bike that the aftermarket industry does not support Fork Braces or Steering Dampeners.
Not that I found a few years ago.
As RJ said, somethings amiss. Steering head, tire, brakes, front suspension, forks & so on.
« Reply #7 on: April 04, 2012, 12:53:52 PM »
 SuperBrace.com actually made one for the valkyrie and had it for sale, until somebody told them the valkyrie has inverted forks and it doesn't work. Their R&D missed that one.
artyc264
« Reply #8 on: April 04, 2012, 01:41:53 PM »
I spoke with Dauntless Sidecar, I tightend the steering head nut. That made a huge improvement. Oh ya, forgot to mention, this is my third bike with a sidecar. Thanks, Arty
« Last Edit: April 04, 2012, 01:43:50 PM by artyc264 » Logged
