February 04, 2026, 04:02:17 PM *
Author Topic: Won't start  (Read 1958 times)
Darren
Lees Summit, Missouri
« on: April 06, 2012, 11:50:54 AM »
Hi Folks,
I need your help.
I took all the tins off my 99 Standard several months ago and sent them to paint. The bike has been in my heated garage and on a motorcycle jack. When I got the tins back(this week) I reconnected all the wires to the rear end, completely reassembled the bike and now it won't turn over. All the lights come on as should. THe headlight goes out when I press the starter button but not a sound. (Kill switch is not on).
I have a brand new battery. (I think the old battery was fine because it did the same thing with it in the bike). I have taken apart the starter button and cleaned it up. I have checked all the fuses that I could find. I have since gone back and checked all connections on the wires that I had previously hooked up. I have checked the batttery ground. I'm not sure where to go from here.
All suggestions welcome and appreciated.
Thanks, Darren
Scott from FL, now in Maine
Augusta, Maine
« Reply #1 on: April 06, 2012, 12:00:50 PM »
I would try to jump the starter relay. The relay may have frozen up. Good Luck I am sure more will chime in soon!
« Reply #2 on: April 06, 2012, 12:01:05 PM »
First, jumper from a known functional battery (vehicle not running).
JC
The Beast
Franklin, TN
« Reply #3 on: April 06, 2012, 12:02:45 PM »
I'd check the interlocks. Is it in neutral, clutch in and kickstand up?
« Reply #4 on: April 06, 2012, 12:05:21 PM »
Including the center cover  Roll Eyes ?
When I took my center cover off, I put the tip-over sensor back on upside down.
So I had to take the center cover off again, and put the tip-over sensor on right.
-Mike "I hate taking the center cover off"
Darren
« Reply #5 on: April 06, 2012, 01:56:22 PM »
Well crud Mike. I did take the center cover off. Which way is the sensor supposed to be sitting? If it is installed correctly is the flat side up or the rounded side?
wild6
(Old enough to know better)
Vernon, NJ
« Reply #6 on: April 06, 2012, 02:08:23 PM »
According to http://www.valkyrieforum.com/bbs/index.php/topic,14204.0.html
it's flat side up.
« Reply #7 on: April 06, 2012, 02:39:39 PM »
Move the ground strap off the aluminum engine block, to the steel frame.  And add a ground strap between engine and frame.  This is something that will likely cause a problem for you if it hasn't already.
Thunderbolt
Worthington Springs FL.
« Reply #8 on: April 06, 2012, 06:16:47 PM »
Flat side up, round side down.
« Reply #9 on: April 07, 2012, 04:34:25 AM »
Been there, done that, so simple but so embarassing!  Good catch hubcapsc. Hoser  Grin
« Last Edit: April 07, 2012, 04:37:02 AM by Hoser » Logged
Darren
« Reply #10 on: April 07, 2012, 12:20:39 PM »
Well...I am a bit embarrassed to say but I installed the bank angle sensor upside down.
She is up and running Thanks to all your help especially Hubcapsc for figuring it out early.
Thanks again.
Darren
« Reply #11 on: April 07, 2012, 07:46:40 PM »
Unbelievable what one can learn by reading various threads!   Shocked   Who would guess it was an upside down bank angle sensor and it would cause so much havoc? Great call hubcapsc!  cooldude
« Last Edit: April 08, 2012, 12:14:42 PM by salty1 » Logged
My rides:
blastedbugler
Australia
« Reply #12 on: April 08, 2012, 01:48:51 AM »
I have an occasional problem with starting on my Interstate.
I have traced the problem to the switch that connects the gear lever while in neutral to the starter / switch.
When in neutral the instrument light shows I am in neutral and it SOMETIMES requires the gear lever to be jiggled to get contact and start the bike.
While I am living with it at the moment I would like to fix it once and for all.
I need help in identifying the location of the wiring switch.
To either clean it up or replace it.
Can anyone advise where to look.
Don ( Aussie )
« Reply #13 on: April 08, 2012, 03:42:37 AM »
Everynow and then my bike's neutral light comes on when it is not really in
neutral... so I mash the starter button and the bike starts rolling  Shocked One day you'll
read in my obituary about how I knocked down all the Valkyries at Inzane like
a line of dominoes...
« Reply #14 on: April 08, 2012, 05:46:28 AM »
That particular switch is inside the motor, behind the cover on the front of the motor.
You should download the manual from Dag's site.
