February 04, 2026, 04:01:44 PM
Opinions on final drive splines
Topic: Opinions on final drive splines (Read 1711 times)
jmann
Mesa,Az.
April 06, 2012, 05:07:02 PM »
If these photos open do the splines look like there is life left or am I riding on a ticking time bomb?
I am most concerned with the splines of the pumpkin hub.
http://vrcc.photostash.com/vrcc_29903/DCAO0092.JPG
http://vrcc.photostash.com/vrcc_29903/DCAO0094.JPG
Valkpilot
What does the data say?
Corinth, Texas
Re: Opinions on final drive splines
April 06, 2012, 05:30:49 PM »
Actually, those are pretty nice.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
April 06, 2012, 05:31:27 PM »
I think your parts should last a long time with proper care... they're
visibly worn, but not trashed...
jmann
Mesa,Az.
April 06, 2012, 05:46:39 PM »
Thanks for the quick feedback. The hub side is worn but I don't think dangerous. The problem is I don't really know when it happened. I bought the bike with 28K and she now has 52K. I have had the tire off twice for new rubber, the last time going darkside. I never really did my due diligence on spline inspection nor was I aware of the PROPER tightening sequence the first time I had it off. I do know the first time I had it apart she was a little reddish and somewhat dry. I peruse this site daily since my valkyrie addiction due to the wealth of info here so now I understand what has to be done correctly. I just didn't know if assembling the parts for a new final drive were in order or if I had time. I plan on the moly paste for the final drive hub parts and grease for the shaft and pinion cup. Thanks for the quick response. Back out to the garage.
April 07, 2012, 04:39:23 AM »
Wish mine looked that good. Hoser
olddog1946
Moses Lake, Wa
April 07, 2012, 10:05:58 AM »
When I pulled mine apart two weeks or so ago to replace the bad left bearing I had the same amount of wear on those final drive splines. (this occurred in less than 2000 miles and an unknown time of riding with a bad bearing)...SO- be sure and check those bearings and replace them if there is any doubt.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
SPOFF
Derry, NH
Reply #6 on:
April 07, 2012, 11:09:36 AM »
That amount of wear can be attributed by not following the proper tightening sequence. (Don't ask how I know this.) I rode splines are worn as yours for 40,000 miles. They eventually wore to less than 50% of the teeth. Then came the day I felt it skip a tooth. I pulled in the clutch coasted through a u-turn and babied it home. I knew if I got a second skip I'd be pushing the bike home.
jmann
Mesa,Az.
Reply #7 on:
April 07, 2012, 08:28:14 PM »
I put mine back together last nite and tightened in the following order:
Installed pumpkin and drive shaft and left the 4 bolts several turns loose.
Installed axle and tire and torqued. Had the swing arm suspended by the LEFT shock only. Right side was removed.
Rotated the tire a few times. Tightened the four final drive bolts.
Was this the proper sequence to hopefully squeeze a few more miles out of the drive gears? Is it better to start shopping for a used final drive or buy the parts and rebuild?
eric in md
Reply #8 on:
April 07, 2012, 08:50:58 PM »
yep sounds like you did it right to me.
i would just make sure you to the final drive service ever 10k should be fine for a long time
