February 04, 2026, 04:02:40 PM *
Author Topic: need info to remove back wheel  (Read 2401 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: April 08, 2012, 02:21:43 PM »
Ok my question is how do I remove the rear tire  and put on a CT .  I have tried all the possible places and no one will mount a CT on a bike, so I will do it myself.   If I can obtain some good instruction from the Gurus here.
  Tony
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
« Reply #1 on: April 08, 2012, 04:15:11 PM »
Youtube is your friend.
Also search. There is a write up about warming the rubber up in the sun first, so it stretches more/better.
HF has 24" tire irons, I bought 3. Read more, and add some plastic covers on the ends, so you don't scratch/scrape your rim (I did).
I would recommend getting another set of hands so you don't slip and scratch your rim. Best advice of all.
« Reply #2 on: April 08, 2012, 04:19:44 PM »
If you get it off the bike, some shops are less paranoid with just a wheel and tire.
If their panties remain knotted, offer them a release of liability (std forms on line).
NITRO
Eau Claire, WI
« Reply #3 on: April 08, 2012, 04:57:38 PM »
Have you asked any car places? There are a couple around here that will mount them, provided that you.buy the fire from them.
When in doubt, ride.
Bone
« Reply #4 on: April 08, 2012, 05:49:36 PM »
Took my first CT to our only bike shop. They took it as a challenge and their machine did mount the tire. The next one no questions asked. Riding by a car tire shop near my home the guys usually wave. I circled back and ask them if my bike shop owner retires would they mount my next rear tire. I pointed at my rear tire I was still on the bike. Man that's a GYTT the guy said. Told them I would bring in the tire and the wheel with out the bike if their changers wouldn't mess up my rim. They thought the wheel would fit and showed me the machine and how it holds the wheel.
I haven't used up the current tire but will give them a try when it's time for a new tire.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #5 on: April 08, 2012, 06:08:53 PM »
Well I tried offering them a release of liability form still NO!!! I just need some info on getting the tire off the bike.  If I do get it off then I will try taking them the tire and RIM and the car tire and see.
Kylenav
Tampa FL
« Reply #6 on: April 08, 2012, 06:12:35 PM »
I went through the same thing when I had mine mounted...  Try telling them that it's for your motorcycle trailer and you just want it to have the matching wheel but a car tire for stability and durability...  As long as I "assured" the manager it was not going on my actual motorcycle they'd mount it.  I little itty bitty white lie and $17 later that bad boy was mounted on the fat lady. Grin :cool dude:
Worked perfectly for me, if you don't mind a little fib give it a try!
Bone
« Reply #7 on: April 08, 2012, 06:13:32 PM »
Was there a owners handbook with your bike ?  My 98 Tourer has one and that is what I used the first time.
Here ya go I just looked in Shoptalk. Click the link. They do the front wheel and then the rear wheel.
http://www.valkyrieriders.com/shoptalk/TireChangeSplineLube.htm
« Last Edit: April 08, 2012, 06:18:18 PM by Bone » Logged
RonW
Newport Beach
« Reply #8 on: April 09, 2012, 01:51:52 AM »
I'm not able to find the post in a very recent thread so I can't quote it, but the poster mentioned rotating the wheel before tightening the '4 bolts' on the pumpkin/swingarm. You're suppose loosen the 4 bolts, then tighten the rear axle bolt, then tighten the 4 bolts, in that order, but are you also suppose to rotate the rear wheel before tightening the 4 bolts. I didn't do that. Or is it even something that you shouldn't do. Sounds fine to me. I just never heard of doing it before.
2000 Valkyrie Tourer
« Reply #9 on: April 09, 2012, 02:04:07 AM »
Dag over across the Pond (Norway to be exact) has a nice site with all the information you will ever need including the shop manual you can download.
http://www.valkyrienorway.com/index.html
Once in there, then hit home and just start looking around for the information ya need.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #10 on: April 09, 2012, 04:28:07 AM »
got a Clymer manual yesterday.  Thanks for all the info.  Will look into everything that was mentioned on this post.   cooldude
Tony
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #11 on: April 09, 2012, 05:21:41 AM »
DuctTape told the shop guy, the wheel was for a "Utility Truck", and got it mounted right then and there  coolsmiley
PhredValk
Edmonton, Alberta, Canada
« Reply #12 on: April 09, 2012, 04:20:31 PM »
I took mine to a quad shop after every car and bike shop in the area said 'No'. They'll put any tire on any rim.
Fred.
VRCCDS0237
« Reply #13 on: April 09, 2012, 06:36:23 PM »
Here is Dag's video on the rear removal.
Rear Wheel Removalpowered by Aeva
VALKIFIED
Sugar Grove Il.
« Reply #14 on: April 10, 2012, 10:51:31 AM »
Just tell "em it's going on a hack.
Some like it fast, some like it long. Valk drivers can give you both
F6MoRider
Lakeland, FL
« Reply #15 on: April 10, 2012, 12:14:43 PM »
Is the Nut modification still needed for clearance?   What are you doing about balancing that new tire?  I use the ceramic bead solution and it's better to consider this in advance as most car shops won't balance them either.
I've found most mom and pop type car tire repair shops are far more flexible in mounting bike tires and even (plug&patch) patching bike tires than most dealer and main stream tire shops.  In Texas, the local bike shops would plug/repair flats, not so here in Florida.  Here they want the sale of the new tire and use scare tactics of it's the only one you have under you...etc and it that doesn't work they say it's against the law.  Hogwash.  Manufacturer sites have repair instructions for bike tires and a recommended number of max repairs.
Car tires seem to last so much longer as well.  No wonder more are going to the dark side.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #16 on: April 11, 2012, 07:27:20 AM »
YOU ALL ROCK cooldude Thanks for the info, now I need to decide what tire to use (Radial ? ) and either dyna beads or ride on, for balancing which is better?  also a couple of different sizes are used on the Valks so which 1 is the best for Florida straight roads with some roads with twisties (not Many)  I will do the nut cage mod while Im there saw somewhere someone had the size carrige bolts that were needed and the how to steps.  Will try to find that again.  Also found a web site No-scufftiretool.com  that shows you how to build your own tire changer for cheap.  $25.00 or so give or take.  There is also a web site mcdarksiders.com with alot of great info there too.  on that web site is a video of a VStar with a radial tire- what are your thoughts, anyone using one and if so what are your thoughts.   Found a guy 2 counties over that will do my tire so I just need to figure out which tire to get and start trying to get the rear tire off.  I will check out the video of Dag as soon as I get this reply sent.   Thanks again to everyone here. cooldude
 Tony
« Reply #17 on: April 11, 2012, 12:39:01 PM »
Might want to view this post. A lot of info exists on VRCC and the VOAI boards on tire changing.
http://valkyrie-owners.com/SMFORUM/index.php/topic,10360.0.html
My rides:
« Reply #18 on: April 11, 2012, 12:41:41 PM »
Also, if you need the service manual go to Dag's site for it.
http://www.valkyrienorway.com/download.html
My rides:
CASABROKER
« Reply #19 on: April 11, 2012, 06:32:36 PM »
195/60/16 no mods at all
