June 23, 2025, 05:47:18 AM
carb "o"rings
Topic: carb "o"rings (Read 2128 times)
art
Grants Pass,Or
Grants Pass,Or
carb "o"rings
May 20, 2009, 04:52:49 PM »
anybody know where I can get the o rings that seal the carb. bowls
Re: carb "o"rings
May 20, 2009, 05:26:35 PM »
if K&L doesn't have them, then it will be a dealer item.
http://www.powersportsuperstore.com/SearchResults.asp?Search=bowl+gaskets&Search.x=23&Search.y=9
this is the tuckerrockey catalog which carries most of the k&L parts.
http://www.klsupply.com/
their site is not good so contact them, they are then very helpful
www.sudco.com
another possible source
John U.
Southern Delaware
Re: carb "o"rings
May 20, 2009, 05:57:09 PM »
I believe Sudco does have them. Try stock # 021-874 at Sudco.com
Jeff K
Re: carb "o"rings
May 20, 2009, 06:42:05 PM »
Any hardware store Dash # 123
art
Grants Pass,Or
Grants Pass,Or
Re: carb "o"rings
May 21, 2009, 11:25:13 AM »
thanks I will try them an see if I can get any
BonS
Blue Springs, MO
Re: carb "o"rings
May 21, 2009, 02:11:13 PM »
You might give this link a try.
http://redeye.ecrater.com/product.php?pid=2064055
John U.
Southern Delaware
Re: carb "o"rings
Reply #6 on:
May 21, 2009, 05:37:51 PM »
Art, In your original post I understood you were asking about the float bowl O-rings. If yhat is the case you don't have many options. Redeye can provide intake runner O-rings (that's the 123 ones) or he can provide a full set to rebuild all the carbs, except for the float bowl.
HDL can provide them for about 50 bucks for the 6, or you can try Sudco. I would call them and ask if the number I mentioned is correct.
Good luck
art
Grants Pass,Or
Grants Pass,Or
Re: carb "o"rings
Reply #7 on:
May 22, 2009, 11:05:31 AM »
thanks I can always buy an "o" ring kit from an industrial supply house like granger an then I will have all the "o" rings I want.Anyway thanks again
=> InZane XXV
