February 04, 2026, 04:01:36 PM *
Author Topic: dark side tire psi dropping  (Read 1271 times)
doniholcomb
« on: April 09, 2012, 04:16:34 AM »
I just took my valk to the darkside, went for a good ride yesterday but I did notice that my tire pressure had dropped, deering the course of my ride. is this a normal thing  or do you guys think I have a problem with it. .
Bone
« Reply #1 on: April 09, 2012, 04:34:56 AM »
Not normal. Listen or use some water around the valve stem looking for bubbles.
Michvalk
Remus, Mi
« Reply #2 on: April 09, 2012, 04:37:11 AM »
I have had this darkside on for over a year, and have not lost more than a pound the whole time. You have a valvestem leak or a leak on the bead of the tire. Could be a bad tire, but , I doubt it. Mix up some dish soap and water in a spray bottle and spray around the valve stem and the bead of the tire. Should get some bubbles where air is leaking out cooldude
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #3 on: April 09, 2012, 04:48:08 AM »
And once you find/eliminate the source of the leak, you may wish to consider adding "Ride On" to your tires...
http://www.ride-on.com/motorcycles.html
