jer0177
VRCC 32975
Pittsburgh, PA
« Reply #1 on: April 09, 2012, 12:38:46 PM » |
If I were you, I would try to rebuild my own. Getting the Rectifier from Honda looks to be about $180, but it could probably be had aftermarket as it's the same one used in the Goldwings.
Quick search on it's part number (31105-MN5-005) comes up with a $65 one on fleabay.
wild6
(Old enough to know better)
Vernon, NJ
« Reply #2 on: April 09, 2012, 12:45:25 PM » |
Check the simple stuff first, like brushes ($2.50 each @ HDL).
BigMac (SoCal)
« Reply #3 on: April 09, 2012, 01:59:39 PM » |
They should be checked and or replaced every 50,000 miles depending on how many lights and or accessories you might be running. I've done mine at 45,000 and 78,000 and it needed brushes both times. I have 107000 on the bike now with no problems with the Alternator.
Dave
CowboyBlue
« Reply #4 on: April 09, 2012, 02:17:45 PM » |
Good advice. Will rip her down and look.
« Last Edit: April 09, 2012, 02:19:28 PM by CowboyBlue »
CowboyBlue
« Reply #5 on: April 09, 2012, 02:30:14 PM » |
How will I know if it is just the brushes? I realize they are super cheap, but what can I do to check the rest of the system?
CASABROKER
« Reply #6 on: April 09, 2012, 03:42:26 PM » |
Take a multimeter to the rotor inside Google testing alternator it will tell you what to do. It will show if you winding is shot. I got the oem hitachi on e-bay $228 no china crap made in Japan. Most after market Chinese
CowboyBlue
« Reply #8 on: April 09, 2012, 06:46:52 PM » |
« Last Edit: April 09, 2012, 06:59:26 PM by CowboyBlue »
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #9 on: April 09, 2012, 07:09:37 PM » |
The pic got kinda blurry when I zoomed in, so I couldn't see how bad the groove is. The brushes don't look too bad if the outer one was the same length is the inner one still is. Check the rectifier and windings to see where your problem lies.
« Reply #10 on: April 09, 2012, 07:52:41 PM » |
First question shoud be, is how is your power needs? Do you need a stock alt, or do you need or could use more power from a high out put one, to power all your extra lights and things?
If stock is good enough, then try to fix your own before you buy a used one. I remember someone somewhere having some nice pictures of brushes, comparing the old to the new (I could even be thinking of the GL1100 starter rebuild). If the brushes are only $2.50, replace them any ways. I didn't check the links, but putting the armature onto a laith and filing it smooth, should go a long way to fix it (don't take off any more than you need to).
CowboyBlue
« Reply #11 on: April 10, 2012, 06:46:14 AM » |
After looking at the images in the tutorial, I see that the brush surface on mine looks the same as the picture in the tut. Ordering the brushes today. By the weekend I'll have something either working or still broken. I'd be out only 10 bucks or so and some practice time putting it back together. Sure will make the honey happy, as I just spent a load on tires.
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #12 on: April 10, 2012, 06:55:56 AM » |
I used to work in an auto parts store and always found it amusing that people would come in for alternators and starters instead of parts to repair them. The major parts of those items - windings, casings, etc, usually don't go bad, and it's the replaceable parts - bearings, diodes, solenoids - that do, and they're MUCH cheaper than the whole unit.
Pete
« Reply #13 on: April 10, 2012, 07:13:27 AM » |
For the time invested in the repair, I would and do go new or rebuilt.
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #14 on: April 10, 2012, 07:30:10 AM » |
It doesn't take much longer to "rebuild" one than it does to replace it. You've already got it out - that was the hard part. To take out a few more screws, check a couple of things, put it back together and save a buttload of money is worth it to me. Example - starter for my truck (beat up old GMC) - Duralast gold - $80. Solenoid for said starter (which is the most problematic part) - duralast gold - $26. It's 2 screws and a nut to replace it. Definitely worth the $54 saving. I guess rebuild companies count on people like that though.
« Reply #15 on: April 10, 2012, 07:47:40 AM » |
It doesn't take much longer to "rebuild" one than it does to replace it. You've already got it out - that was the hard part. To take out a few more screws, check a couple of things, put it back together and save a buttload of money is worth it to me. Example - starter for my truck (beat up old GMC) - Duralast gold - $80. Solenoid for said starter (which is the most problematic part) - duralast gold - $26. It's 2 screws and a nut to replace it. Definitely worth the $54 saving. I guess rebuild companies count on people like that though. Jeremy, where was your signature picture taken?
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #16 on: April 10, 2012, 07:54:50 AM » |
That was last August on the Dragon. Katie and I rode the BRP North to South over the span of a week or so - did about a hundred miles a day and a lot of sightseeing, hiking, etc., then hit the Dragon when we were done with the Parkway. It was an awesome trip.
Red Diamond
« Reply #17 on: April 10, 2012, 07:41:07 PM » |
By the time you get that alternator out, fiddle fart with it trying to repair something you probably don't have the proper tools to repair it with, then fiddle fart with putting it back in, only to find out it still doesn;'t work. Do the simple thing first, buy a new one. You will be happier for it. Also there is a company in Arizona, that sells one with a two year warranty for about 227 dollars.
macdoesit
« Reply #18 on: April 10, 2012, 09:30:47 PM » |
Had my alt rebuilt in Ardmore Okla my home town Buttons auto elect. 12 dollars.
CowboyBlue
« Reply #19 on: April 11, 2012, 08:10:01 AM » |
It actually is just like rebuilding an automotive alternator. Not difficult. And the local dealer had the brushes for $5.00. So after rebuilding and installing, if it doesn't work, I'm out $5.00 plus will have gained valuable experience into the matter. Then I can buy a new one. It's literally 3 simple 12 mm bolts, plus I did not remove the plug. I was able to unhook from the back of the alternator. If it works, it's so simple it hurts. Getting it past the frame was pretty easy once I read the tutorial. Remember to tilt "in-board" with the rear of the alternator. I removed the overflow tube and it was a snap. Even with the noise filter on the back of the alternator (IS version). I'd be unafraid to do it over.
« Reply #20 on: April 11, 2012, 09:52:14 AM » |
Ken, the MARS guy told me the biggest problem with the alternators is with the windings on the armature. He said they break and become intermittent conductors.
He rewinds the armature himself and then tests them.
Not something I would attempt to do.
CASABROKER
« Reply #21 on: April 11, 2012, 06:40:49 PM » |
Check the winding with the meter if you don't you'll be cussing for sure. No quick rebuild if they're toast. Can we say buy a new one.
CowboyBlue
« Reply #22 on: April 14, 2012, 03:12:43 PM » |
Yep. Toast. New brushes installed. Windings junk. Time for new. Put her together in about an hour. Oh well...
CowboyBlue
« Reply #23 on: April 14, 2012, 03:17:39 PM » |
anything else i can check?
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #24 on: April 14, 2012, 05:33:12 PM » |
Do you have a multimeter? If not, an el-cheapo from any auto parts store will work - as long as it measures resistance/continuity. Check the windings as has been mentioned - make sure you're getting continuity between each "ring" (copper band), and none between either ring and the shaft. If these both pass, the windings are good (or the if you have an intermittent problem, the intermittent connection is connected). If those pass, and you've replaced the brushes, it's gotta be the rectifier / regulator which is internal to these alternators. The Honda part number is 31105-MN5-005 but there are aftermarket ones available ( http://www.oldbikebarn.com/Honda-GL1500-Goldwing-Valkyrie-Rectifier-Regulator).
CowboyBlue
« Reply #25 on: April 23, 2012, 08:54:38 AM » |
Sorry for the long wait for a reply. I did in fact order a brand new 85 amp alternator off of ebay. My internal regulator was toast.
It must have been clocked for a goldwing. After about 5 minutes of trying to install I remembered to check it. It needed to be clocked and it went in fine. I also had to remove the little filter for the radio that is attached. It was easy to bolt it on once the alternator was installed.
Using heavy grease, I was able to "stick" the dampers to the internal housing so that they didn't fall in my way for the impeller. Quite easy after all. Next time I'm just gonna get a new one. Charges quick. Works great. 1 year warranty.
IMHO: Just replace it with new. Don't mess around.
« Reply #26 on: April 23, 2012, 11:41:31 AM » |
There is also a Gold Wing Alt that will fit and work just fine. Right column, 3/4 way down. http://www.jkozloski.com/generic_parts.htmSave this link in your favorites, you will be surprised how many times you will refer to it.
CowboyBlue
« Reply #27 on: April 23, 2012, 01:10:29 PM » |
Awesome! Thanks!
