February 04, 2026, 04:03:07 PM *
Author Topic: shuts down while drving  (Read 1550 times)
slider
mulberry arkansas
« on: April 10, 2012, 08:07:29 PM »
driving down interstate had drove about  10 miles  running aout 70  and engine shut down sounded like  she does just before I have to go to reserve -coasted to  side and tried to start,turned over fine but no start,sat for about 2 minutes and she fired right up and ran great for about 8 miles and again shut down,went thru same procedure and she started up,I go off interstate and drove a slow 60 back home a distance of about 20 miles with no problen at all  ckecked tank vent  and it had no kinks idles fine does not miss at any speed,starts easily,,runs as normal except for shutting down..have good fuel with startron in it,also have in line filer that was put in about 6 months ago,put in new airfilter(OEM) a month ago..any  Ideas....thanks in advance
a proud navy veteran
Mr. Nuts
Bitterroot Valley Montana
« Reply #1 on: April 10, 2012, 08:31:25 PM »
Not saying this is your problem, but I had the same symptoms after installing an inline filter , new fuel line, and Pingle petcock. Drove me crazy trying to figure it out. Turns out the fuel line was just a bit too long after adding the filter. When the line got warm, and fuel draw was heavy, the line would kink restricting the flow. Like a bent up straw and someone sucking too hard. It was sporadic and hard to diagnose. Cut the line very short and the problem was fixed.
Good luck!
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
ValkFlyer
Antioch, CA
« Reply #2 on: April 10, 2012, 09:29:33 PM »
What model ignition module do you have, OEM or DynaTech.?
John U.
Southern Delaware
« Reply #3 on: April 10, 2012, 09:52:52 PM »
It could be a clogged vent line from the gas tank. When this happens try opening the filler cap and see if you get a whoosh as air enters the tank.  The rubber hose that attaches to the tank vent nipple by the petcock may be clogged or kinked.
john
tyler texas
« Reply #4 on: April 10, 2012, 10:01:16 PM »
fuel starvation ...
 kink in line ?...
petcock rebuild  ?
« Last Edit: April 10, 2012, 10:04:06 PM by john » Logged
vrcc # 19002
« Reply #5 on: April 10, 2012, 10:14:26 PM »
Ya had the gas tank off recently?
IF so, find the kink in your vent hose and straighten it out.
slider
mulberry arkansas
« Reply #6 on: April 10, 2012, 11:43:20 PM »
yipe had taank off to put in filter,lo and behold the vent line had a kink,,thanks for everyones help
« Reply #7 on: April 11, 2012, 05:44:19 AM »
Sounds like a classic kinked vent line, original post stated this line was checked and no problem was found.. Its nice that some folks insisted it was still the problem,, good..
« Reply #8 on: April 11, 2012, 06:23:00 AM »
With a kinked vent line, wouldn't a vacuum be created in the tank and wouldn't that be apparent when opening the gas cap?  Undecided
My rides:
slider
mulberry arkansas
« Reply #9 on: April 11, 2012, 08:34:50 AM »
first time i checked for kinked event hose i just took off the seat..second time i removed the tank.thanks to  all for the great advise...Im still learning from you pros..
