February 04, 2026, 04:02:35 PM *
Author Topic: Tire wear  (Read 1537 times)
Chiefy
Sarasota, Florida
« on: April 11, 2012, 09:01:57 PM »
Have a set of Metz 880's.  I don't know how many miles on the front.  It was on there and looking pretty new when I bought it 8,000 miles ago.  Tire is about ready to be changed.  When I looked it over, I noticed there was more wear towards the left (from the riders perspective) then the right.  I assume that's from the crown in the road??  But I've never seen it mentioned here, so thought I'd ask.  Bike tracks straight and true, just about like a small chopper I had so many years ago.  No head shake or shimmies.
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: April 11, 2012, 10:43:42 PM »
Do a search from the Home page, lots of info. Crown in the road and left turns are longer than right turns. British bikes wear on the right...
Fred.
VRCCDS0237
Brian
Monroe, NC
« Reply #2 on: April 12, 2012, 03:15:05 AM »
Yep, common problem. I bet you hit the left hand turns harder and lean more than you do on the right?
Chiefy
Sarasota, Florida
« Reply #3 on: April 12, 2012, 04:05:43 AM »
Thanks guys.
We have some pretty high crowns in a lot of the roads I ride on here in Florida.  And yes, because of the crown I guess I turn left harder then when I turn right.  Although with these crowns you can run out of clearance fast on a left turn.
« Reply #4 on: April 12, 2012, 05:23:14 PM »
Pretty common wear pattern. Do you feel more comfortable in left turns than to the right? I do and tend to take them more aggressively.  Evil
My rides:
Sam Shlitz
SoCal
« Reply #5 on: April 12, 2012, 08:41:53 PM »
I've learned and implemented two tricks: keep your tires slightly overinflated and try (when possible) to drive in the left lane. It really makes a difference. Look up the previous discussion (about a month ago) and you will see my post to the board about the same problem I had. Since I added pressure to the tires and started to ride mostly in the left lane I noticed my tires wear started to even out.
It is like getting free mileage by riding the right side of the rubber. Last set of tires I replaced had a completely worn left side with practically full thread on the right side (what a waste!)
Ride safe.
« Reply #6 on: April 13, 2012, 05:39:18 PM »
If you feel more comfortable turning one way over the other I recommend to you what I did.  I cannot even remember which side I favored now, but when I realized I didnt feel comfortable leaning into a turn (left or right) I made sure I made that turn OVER AND OVER until I felt as comfortable as the strong side.
Now I can scrape either peg just as comfortable and I dont even think about it.  Its not good to have a side you dont trust
