February 04, 2026, 04:01:00 PM *
Author Topic: Fork Rebuild & Steering Head Bearing Replacement Need tools  (Read 1673 times)
moreira72
VRCC# 33494
Clark, NJ. 07066
« on: April 12, 2012, 06:49:11 PM »
Hi everyone,
I am going to rebuild my forks and put new bearings in the steering head while i have it apart.
I have ordered all the parts, Fork seals, Progressive Springs, Honda Suspension Fluid 10w, and new head bearings. The wheel bearings were done at last tire change(750miles ago) so they are good.
I should get the parts this weekend.
What i don't have are the 3 tools for the job. The Seal driver, and the two sockets for the left fork and steering head nut.
Does anyone have these and are willing to loan, or rent to me. I would cover shipping both ways and pay a rental fee if applicable.
I just don't want to buy three new tools for over $125 that I'm only going to use once.
Or is there a way to do the job without them.
I can pay cash, MO, Or Paypal.
I'm in Northern New Jersey
Thanks in advance to the wonderful people on this board. Paul
« Last Edit: April 13, 2012, 01:29:23 AM by moreira72 » Logged
wild6
(Old enough to know better)
Vernon, NJ
« Reply #1 on: April 13, 2012, 07:29:27 AM »
I had done the progressive springs and seals about 6 years ago and didn't use any special tools.
Didn't need to remove the t either. (The fork tubes just slide out)
Unless the head bearing is giving you problems, just grease and torque it and it should be good (mine is 108k miles old and still working fine).
Some links with help:
http://www.valkyrieforum.com/bbs/index.php/topic,17446.msg148180.html#msg148180
http://www.valkyrieforum.com/bbs/index.php/topic,32950.0.html
« Last Edit: April 13, 2012, 07:31:05 AM by wild6 » Logged
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #2 on: April 13, 2012, 01:43:43 PM »
How do you replace the springs on the left fork? Manual says to remove nut with special tool to remove spring?
wild6
Vernon, NJ
« Reply #3 on: April 13, 2012, 02:40:44 PM »
There's a link in the second post of the second link above to a site that shows how do-it-yourself-fabrication of some special tools was accomplished.  It includes the 'fork spring tool' needed here.
I think I may have used a screwdriver and hammer to break it loose (being very careful not to damage anything) and then, a long nose pliers (each half of the nose in opposite notches) to turn it loose.  It was a long time ago (by my feeble memory).
« Reply #4 on: April 13, 2012, 03:26:17 PM »
Someone (I don't even remember who now) loaned me the tool, made it easy. I we keep your
post bumped to the top for a day or two perhaps someone with the tool will see it...
You have to overcome a spring on both sides, I used a plumbing elbow on the
non-special-tool side...
Chattanooga Mark
« Reply #5 on: April 14, 2012, 06:27:17 AM »
If you do need the special tool to adjust the steering stem nut, this one from Mike works well:
http://www.valkyrieforum.com/bbs/index.php/topic,38473.0.html
Scroll to the bottom of the page.
All the best,
Mark
www.bikersforchrist.org
