t-man403
Valk-a-maniac
Calgary, Alberta, Canada.
« on: April 14, 2012, 01:32:26 PM » |
How much does a Standard weigh? Looking at a 1000lbs capacity lift table. As of now I have a 1500 motorcycle lift. 500lbs capacity difference. I bought the lift adapter as well. Does the lift adapter stay on the bike, if so what is used for mounting it, or do you take it off. Thanks in advance.
Bone
« Reply #1 on: April 14, 2012, 01:40:10 PM » |
The manual has the dry weight at 681 lbs.
Maybe the weight is posted on the neck area tag.
WDAN
« Reply #2 on: April 14, 2012, 01:52:34 PM » |
The lift adapters come both ways. The one I bought was made to be permanent mount.
WDAN Irving, TX
« Reply #3 on: April 14, 2012, 03:06:21 PM » |
Mine weighs half a ton with a full tank and me and a weeks luggage aboard. Course I only weigh 160.  hoser
« Reply #4 on: April 14, 2012, 05:04:26 PM » |
Dry weight on my '98 tourer is 719# (CA model). With fluids I figure 750 lbs. An interstate is over 800#.
NITRO
« Reply #5 on: April 14, 2012, 05:41:21 PM » |
Keep all of that heavy safety chrome in mind, too. As well as any other accessories you may have added.
When in doubt, ride.
t-man403
Valk-a-maniac
« Reply #6 on: April 14, 2012, 09:04:48 PM » |
Thanks for the info. I found this tonight. Specifications Top speed 115mph 1/4-mile acceleration 12 secs Power 100bhp Torque 87ftlb Weight 309kgSeat height 740mm Fuel capacity 20 litres Average fuel consumption 33mpg Tank range 120 miles Insurance group 14 Engine size 1520cc Engine specification 12v, flat six, 5 gears Frame Steel diamond Front suspension adjustment None Rear suspension adjustment Preload Front brakes Twin 296mm discs Rear brake 316mm disc Front tyre size 150/80 x 17 Rear tyre size 180/70 x 17 So the lift table will have 300lbs. of capacity to spare.
KSDragonRider
Salina, KS
« Reply #7 on: April 15, 2012, 11:35:10 AM » |
I have the old Harbor Frieght narrow drop tail 1000# lift, and it has no problem with my valk up as high as it can go. I added a 5' piece of angle to the front to spread out the tie down locations as i dont trust a wheel lock, and when it is up all the way, I put a couple jack stands up under the angle to add some support. So far it has worked great! In these pics you can see the angle and the tie downs with lift up maybe 2'6" up from full down position. The drop tail is super nice to pull a tire with out pulling the fender.
Dalen & Shay -> Salina, KS VRCC Member #33950 1999 Red & Black Valkyrie Interstate
t-man403
Valk-a-maniac
« Reply #8 on: April 15, 2012, 02:35:44 PM » |
Wow! Thanks for posting the pictures. This is the one that I'm looking at. Other that those screw down stops at the front, I see nothing else to provide stability. Being narrow like it is makes me nervous. Need some outriggers of sorts. I'm just going to go have a look at it now. Thx!
PhredValk
« Reply #9 on: April 15, 2012, 07:07:54 PM » |
You could clamp or bolt 5-6' cross pieces fore and aft for satbility... Fred.
Tx Bohemian
« Reply #10 on: April 16, 2012, 06:09:06 AM » |
I have the 1000# HF, foot operated, lift. I changed the wheel clamp to the one from the air/hydralic lift, and positioned it a bit more forward to get the bike more over the rear wheel hole. It looks alot like the blue one pictured (but red).
I can't tell how wide the one in the picture is and I'm sure this isn't recommended, especially by the manufacturer, but I have rolled mine around with the Valkyrie on it in the "jacked up" position. Usually just about 7-8' forward to drive my truck in the shop overnight then back to finish work on it the next day. I take my time and am extremely careful but it also is very stable. Also the concrete in my shop floor is really smooth.
Remember, if you are on a bike and wreck with a car no matter how "in the right" you are you are going to lose. RIDE LIKE EVERBODY IS OUT TO GET YOU!! Al
t-man403
Valk-a-maniac
« Reply #11 on: April 16, 2012, 03:55:57 PM » |
 holy cow! Mind you another guy told me his was very stable as is and he lifts a Nomad. These lifts are on for $399.00 starting tomorrow so I'll be down there when the door opens as they only have 4 of them on hand.
olddog1946
« Reply #12 on: April 17, 2012, 08:11:57 AM » |
I am currently working on a bmw K1200lt (833lbs dry weight), using a borrowed HF 1000lb lift. and is works great. I did have to put jack stands under the front to hold the lift from tilting when I lifted the frame to remove the trans, swing arm, final drive and tire, which leaves about 20 lbs on the back end.
the lift adapter is mounted between the kickstand and the cross bar and stays on the bike.
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
Tx Bohemian
« Reply #13 on: April 17, 2012, 01:40:35 PM » |
These lifts are on for $399.00 starting tomorrow so I'll be down there when the door opens as they only have 4 of them on hand.  Unless I missed it I didn't see what brand of lift you are looking at. If it is a HF go look through some motorcycle magazines, usually they have a page of coupons from HF. I got mine for $279 w/ coupon. Something like $120 off. When I bought mine a member here, or maybe another board I'm on, mentioned that "Cycle World" mag had the coupon and I looked "high and lo" in my town and couldn't find a Cycle world mag to save my soul!! But did find one in another bike magazine. Even if your too late reading this and have already bought the lift and then found the coupon go back and see if they'll honor it, all they can tell you is no.
F6MoRider
« Reply #14 on: April 17, 2012, 02:03:27 PM » |
And if they say no, return it, then buy it back with the coupon.
VRCC #4086 2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
t-man403
Valk-a-maniac
« Reply #15 on: April 17, 2012, 10:51:24 PM » |
These lifts are on for $399.00 starting tomorrow so I'll be down there when the door opens as they only have 4 of them on hand.  Unless I missed it I didn't see what brand of lift you are looking at. If it is a HF go look through some motorcycle magazines, usually they have a page of coupons from HF. I got mine for $279 w/ coupon. Something like $120 off. When I bought mine a member here, or maybe another board I'm on, mentioned that "Cycle World" mag had the coupon and I looked "high and lo" in my town and couldn't find a Cycle world mag to save my soul!! But did find one in another bike magazine. Even if your too late reading this and have already bought the lift and then found the coupon go back and see if they'll honor it, all they can tell you is no. Up here our HF is called "Princess Auto". I'm sure they are one in the same as the sell a lot of the same stuff. There are no coupons offered here like you guys get in the States. I was just happy to get one as they only had four. Regular price is $499.00. The one with the pneumatic jack is $599. I'll put it together on the weekend after my back heals up from unloading it.
Tx Bohemian
« Reply #16 on: April 18, 2012, 07:54:52 AM » |
First off, congradulations on the lift table. I really enjoy mine and it is well used not just for my bike but other stuff as well (I "bohemian rigged" a bigger, removable tabletop so I can put my riding lawnmower on it too, which this also works well for an adjustable work bench). There are no coupons offered here like you guys get in the States. Wow! that kinda sux! I'll put it together on the weekend after my back heals up from unloading it.  I understand, I had help at the store to load it in the back of my truck but had to unload it by myself. The young guy at the store even complained about it being heavy and he was using a forktruck to load it!
Tx Bohemian
« Reply #17 on: April 18, 2012, 08:07:25 AM » |
One other thing: If these are the same as the HF be careful running the bike on and off. I dropped my bike once as I was backing it off. I had the kickstand down and it caught on the top of the ramp. It tilted to the other side, I lost the balance and once it started going that was all she wrote!! Luckily there was no one, or no dog (their always hanging around), on that side.
Once I got over being shook up I was really PO'd because I just got through putting my National Hard bags on and figured the right one bound to be crushed, but it wasn't. Just a little scuffed. Then I was totally impressed!
t-man403
Valk-a-maniac
« Reply #18 on: April 18, 2012, 09:43:52 PM » |
Thanks for the heads up. Of course I put the crate in the garage wrong way around. Open the crate and the ramp end is toward the front of the garage!  I have to say it was an uneasy feeling putting the bike on the lift and was even a worse feeling lifting it up. I'm sure like anything I will get used to it in time.
Tx Bohemian
« Reply #19 on: April 19, 2012, 05:19:10 AM » |
I have to say it was an uneasy feeling putting the bike on the lift and was even a worse feeling lifting it up. I'm sure like anything I will get used to it in time. Yeah, know what you mean, and you will get used to it. Good lookin table. I see there are a few differences than mine. Yours has four of the screw down stabilizers and mine only has the two on the front. Mine has a rod that you shove through the front lifting arm to prevent it from lowering unintended (saftey thing), I don't see that on yours, does it have a catch of some kind?
t-man403
Valk-a-maniac
« Reply #20 on: April 19, 2012, 07:21:12 AM » |
Good lookin table. I see there are a few differences than mine. Yours has four of the screw down stabilizers and mine only has the two on the front. Mine has a rod that you shove through the front lifting arm to prevent it from lowering unintended (saftey thing), I don't see that on yours, does it have a catch of some kind? [/quote]
This table is not like the one advertized as it has a couple things different from the flyer picture. The stablizing feet and the safety lock bar. On this one you can see it on the back stand. It's a bar on both sides of the stand that drops into a notched track on each side. Probably about 10 notches so it locks at whatever height you want. I think I'll put some eye hooks on the corners to allow for tie down straps.
« Last Edit: April 19, 2012, 07:23:16 AM by t-man403 »
